PCV Valve Hookup
I replaced mine because it also had those 2 connections, one capped and one went to the valve cover (351w) ... I was thinking it was an aftermarket job so I pulled it out.
So I bought one from the Ford dealer and guess what -same thing, 2 connections but there was rubber cap included to seal off one of the ports.
I just re-installed using the same configuration as the one I pulled out... beats me why they come like that unless the ports are of different sizes for different applications.
My Haynes manual did not shed any light on this, so I re-installed it using the same configuration as the old one.
after way too many years of working on ford industrial 300's, I can answer this question. Ford in their infinate wisdom used the same pvc valve for multiple applications. The top port is used for some emission control operations, for those other uses the top port is simply blocked off. hope this helps
Thanks for the input oldschool63! Its been bugging me for months about thoses 2 ports. Do you know which vehicles might have used both or the other port, or why?
Funny that Haynes does not mention this - unless I've missed it.
mrstace84 - there are some other threads regarding PCV and re-routing the intake FROM cyl 8 TO the vacuum plenum (tree) to avoid fouling.. sorry I don't have the info handy but will post later if needed.
Not sure if it applies to your 84 truck though ..mine's a 1989.
-rlp
-rlp
sorry it took so long to reply. As for that upper port being used, it all depended on where the truck was built for and what type of emissions it had. I've seen the same year and model with different routings and for no real reason i could determine other than the emission package it was sold with. Or it could just be a Ford thing! : )
ItsAFord55
12-27-2015 07:11 PM
maxride
08-28-2015 05:54 PM
Aune163rd
23
09-01-2014 02:28 PM
MRStace84
11-14-2012 08:29 PM
84 f250 6.9
08-27-2009 10:12 AM
