5.4L spark plug problem
I have read many threads on this problem (blown plugs) but have not found any agreement on when Ford actually fixed this problem. When did Ford fix the spark plug blowing problem? I have heard 2000, 2001 and 2003. Which is it? Did they go to a plug with more threads?
Thanks
Thanks
I heard November 14 2002 was the switch day. If you have a 2003 1/2 you should have the improved design. Look on your passenger side head between cylinder 2 and 3, there's a date and time printed in ink on the aluminum head. The new heads should have 8 threads instead of the 4 on the older designs.
v10Mustang:
Hmmmm.....i ordered my 2002 truck in November 2001 and it was delivered December 2001. Does my 5.4 have the 'short thread' design?
And does a 'short thread' owner have to just sit back and wait for a plug to blow, or is there some type of preventative maintenance that can be performed? I have an extended warranty on my truck up to 72,000 miles. I'm at 34,000 miles currently, and so far my 5.4 runs great....does anyone have some wood i can knock on????
-hooD
-hooD
The date code is a lot harder to see on a 4WD F150 because you don't have the coil cutout in the wheel aprons, but you could look at the date code of your engine. (it's on a white sticker on the driver's side valve cover near the oil dipstick.) The heads are usually made within a few day's time of the engine block. My heads say 05/01/03 while the engine says 05/02/03.
Ricks6speed
1999 to 2016 Super Duty
33
02-05-2016 08:11 PM
thegreatgate
2004 - 2008 F150
08-02-2014 05:48 PM
