block bolt pattern question
Old 11-11-2003, 05:41 PM
stargazer's Avatar
stargazer
stargazer is offline
Question block bolt pattern question
okay a buddy asked me the other day if the flathead had the same block to clutch housing bolt pattern as the Y and FE. I told him I wasnt old enough #1 to know this and I have never seen a flathead close enough to know. I said I would ask. is it the same?
Old 11-11-2003, 11:16 PM
mtflat's Avatar
mtflat
mtflat is offline
I don't have a Y block or FE to compare, but I've been told the flathead is unique and won't match the others.
Old 11-19-2003, 07:53 AM
Paso1's Avatar
Paso1
Paso1 is offline
I'm pulling the 239 flathead out of the 54 and installing a 292 from a 61 I've been told it's a straight bolt in, I'll find out next spring for sure. Apparently the US made 54's had some OHV Y blocks installed but the Canadian built still used the 239 flatheads model Q & model QHS show in the 53 parts manual as having the Y block.
Old 11-20-2003, 05:28 AM
ke6bnl's Avatar
ke6bnl
ke6bnl is offline
I have a 239 flatthead and a 3speed on the floor, what newer motors are a bolt in thanks as a kid I had the same truck it had what I was told a 57 ford motor 289??? if the motor is shot I may go with a newer style ohv motor. thanks Ed ke6bnl
Old 02-07-2004, 06:16 PM
312's Avatar
312
312 is offline
the 292 will fit if you have the complete motor including bellhousing.all 54 fords in the u.s. were overhead.all in canada up to at least 3 ton were flathead.i was told this happened because ford in the u.s.had a mountain of flatheads left over and basicly dumped them on ford of canada.
Old 02-07-2004, 07:09 PM
Steve_B's Avatar
Steve_B
Steve_B is offline
I have a South African Built 54 F100 which has the original Flathead, also right hand drive
I believe Australian and New Zealand trucks are the same
Old 02-08-2004, 08:46 AM
312's Avatar
312
312 is offline
steve,as far as i know all australian and new zealand fords wereimported from canada.i would be willing to bet that the same was true for south africa.
23
11-18-2009 04:49 PM
89ford73
27
10-29-2008 10:01 PM
pcmenten
20
08-08-2007 06:08 PM
loosecannon39
Flathead V8 & Flathead 6
04-22-2006 01:38 AM
Quick Reply: block bolt pattern question
