1988 f150 clutch push rod
Old 01-03-2000, 08:17 PM
tony_1's Avatar
tony_1
tony_1 is offline
my 1988 f150 300 6 cyl clutch master cyl push rod plastic bushing is worn. how do i pull the pin??
looks weird. thanks
Old 01-04-2000, 10:21 AM
deleontow's Avatar
deleontow
deleontow is offline
Just pull the pin, you may have to turn it and just pull it out, once out, pull the clutch rod off to on side and replace the bushing, though check the area were the bushing goes, as when it wears out, it tends to wear the linkage where the rod goes and you have to replace this if this is the case. All available through ford
Dave
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Old 01-27-2000, 01:37 AM
SPLabar's Avatar
SPLabar
SPLabar is offline
Beware of the pushrod breaking. In my experience once the bushing wears out the pushrod eye usually breaks soon after. I have broken 3 or 4 over 100,000 miles. I have replaced the arm that goes on the clutch shaft to no avail.I finaly made one out of steel a few months ago. This one won't break.
Old 01-27-2000, 01:44 AM
SPLabar's Avatar
SPLabar
SPLabar is offline
gtcrackers
15
09-13-2020 11:30 AM
biker art
06-30-2017 02:53 PM
Dstosh
1999 to 2016 Super Duty
10-01-2016 10:08 PM
kellen302
01-29-2016 02:11 PM
83red150
12-22-2006 02:32 PM
Quick Reply: 1988 f150 clutch push rod
