F150 Load Capacity
Old 11-06-2003, 11:48 PM
Phobia16V's Avatar
Phobia16V
Phobia16V is offline
F150 Load Capacity
I'm a little confused about what the actual load capacity of my truck is(ie: weight in the bed). My rear axle code is 19, so according to my owner's manual, the truck has a GAWR of 3800lbs. There is no way that the truck on it's own(unladen) is taking up 2800lbs of rear axle capacity, even with 2 full fuel tanks. Something isn't adding up here.
The reason I ask is that I have a load to haul 400 miles that weighs somewhere between 1200 and 1400 lbs, and I want to make sure that the truck can handle it safely.
Old 11-07-2003, 06:34 AM
rlp's Avatar
rlp
rlp is offline
Phobia16v ... check out this thread
https://www.ford-trucks.com/forums/s...%25252Bpayload
I and others had replied to this common question. You can also try a search on this forum on "f150 payload" (go one year back) for similar discussions.
Hope that helps -rlp
Old 11-07-2003, 10:19 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
If you lived in California, it would be easy, the difference between the GVW on the sticker and the unladen weight on the registration. My '94 4x4 for example:
6250-4425=1825
Subtract 6lbs per gallon of gas and driver weight and you have it.
1825-(6*20)-150=1555
Jim
Old 11-07-2003, 10:27 AM
First Ford Truck's Avatar
First Ford Truck
First Ford Truck is offline
You probably will want to air up the tires to their maximum when carrying that much weight.
Old 11-07-2003, 12:06 PM
jeffthompson's Avatar
jeffthompson
jeffthompson is offline
If you got 1400 lbs in a f150 you should have no problem.
I've repeatetly hauled 2200 on bumpy dirt roads with my salt damaged rusty suspension and only got minor damage.
1400 is a walk in the park.
Old 11-09-2003, 10:40 PM
Phobia16V's Avatar
Phobia16V
Thanks for the replies everyone. Though I didn't get a total weight of the truck with or without the load, it made the trip just fine! I was actually quite pleased with it's performance. After over 400 miles with that load, I still have 1/2 a tank of gas left.
Old 11-11-2003, 10:01 PM
Greasemonkeyjoe's Avatar
Greasemonkeyjoe
Greasemonkeyjoe is offline
I have a dealer brochure for my 96 and you should be able to handle 2200 in the bed so 1400 would go no prob
Old 11-11-2003, 11:12 PM
acerockola77's Avatar
acerockola77
acerockola77 is offline
I hauled 3500 in the bed of my F150 for 500 miles.. You're fine.
Old 01-19-2004, 10:40 PM
jbbrtabla2's Avatar
jbbrtabla2
jbbrtabla2 is offline
payload
I just aquired a 1995 f150 w/ I suppose standard suspension,
and 800lbs of compost brought the rubber stop on the frame
within 2-3inches of the axel. Isn't that rubber stop some kind of
indicator of payload capacity
Old 01-20-2004, 12:13 AM
quaddriver's Avatar
quaddriver
quaddriver is offline
FYI - yes, the 8.8 can take a 3800 lb load before things start falling off it. outside of the USA, with the contact overload option, there is an 'ambulance package' for the F150
not all f150s are 6250 GVWR tho....you need to peek at your little sticker. the 2wd models start around 5250 for a light duty shortbed stepside. I have the chart in my manual (which I still have!) but its snowing and 2* outside so tough.
keyul
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
19
03-28-2017 03:22 PM
Doonz
1999 to 2016 Super Duty
09-06-2013 09:09 AM
95e150CW
06-24-2012 09:56 AM
Jrhere2003
06-10-2010 02:54 PM
DMoor5
04-28-2009 03:01 PM
Quick Reply: F150 Load Capacity
