AC Compressor still does not work, low pressure switch???
My AC just stopped working. I replaced fuse and Wide Open Throttle relay. Still no go. Checked and added refrigerant, still no go, even though it cycled on and off for about ten times. Connected battery directly to compressor, it engaged and cooled the truck. Someone said the low pressure swith maybe faulty. Any ideas?? Can I bypass the switch and check it. Can I change switch and not evacuate system?? Any ideas would be appreciated.
Liltruck
Liltruck
No code was pulled. The compressor was simply not engaging so I first checked the plug on the compressor and no voltage was getting to plug. I then checked fuses and relay. All were fine. I checked the refrigerant with an Auto Zone kit and levels were fine. I then went to low pressure switch and did a voltage check. 12 volts was coming in and 2 volts was going out. I was told that if everything was working right 12 volts should be going out which should then turn the compressor on. I replaced the low pressure switch and everything worked!!!!
Liltruck
Liltruck
Sorry, just short for Heating Ventilation and Air Conditioning system. I get nothing but the hot air you would expect when it's dialed to the hottest setting, even when I have it on max a/c and set at the coldest setting. Same with all other combinations and settings. Air's always hotter'n hell. I get no codes, there's no info stored in the computer about, no noticeable vaccuum problems. I was hoping you had similar symptoms so that I could be optimistic about getting off cheap for once
The compressor was simply not engaging. When I would turn on the AC, the compressor would not engage and thus no cool air would come out. I first checked the plug on the compressor and no voltage was getting to plug. I then checked fuses and relay. All were fine. I checked the refrigerant with an Auto Zone kit and levels were fine. I then went to low pressure switch and did a voltage check. 12 volts was coming in and 2 volts was going out. I was told that if everything was working right 12 volts should be going out which should then turn the compressor on. I replaced the low pressure switch and everything worked!!!!
Liltruck
Liltruck
I have a 4 cylinder. Looking at the engine the switch is on the left side. Start with the compressure and follow the the hose from it that goes to the left. You will see a black and silver thing that kinda looks like a spark plug with wires attached to it. That is it. I unplugged it and twisted it off by hand, twisted the new one on and replugged it. There is a similar item on the right side of the compressor. I think that is the high pressure switch. Good luck.
Hi Liltruck:
Well I did what you said and as I was untwisting the low pressure switch a lot of pressure plus a green liquid began to oozze out, so I quickly tightened it back as dreaded it may well be the cooling gas Freon. Maybe it is low on this gas and maybe because of this the AC is not working. As you said your compressor began to work but does it cool?I think I´ll take it to a specialized shop to see if the can help me cheap. Perhap I may get away with a re-fill? after all it has never been recharged in 7 years.
Cheers Karslake
Cheers Karslake
AC Problems
After the low pressure switch was replaced the AC cooled like a champ and is still doing fine. In reference to losing refridgerant, when I twisted the valve off, there was an instant pressure release but no significant loss of any refridgerant. The base of the switch has an o ring and the new switch has a new o ring which I believe keeps the freon from escaping. I am not familiar with other switches and don't know if they are different or not. My truck is a 96 with the standard 4 cylinder. I am pretty careful around AC repairs and would recommend bringing your problem to a pro. if you lack familiarity with the needed repair.
