Code P1131 and P1151
Old 10-14-2003, 07:08 PM
aggiepapa72's Avatar
aggiepapa72
aggiepapa72 is offline
Lightbulb Code P1131 and P1151
My '98 Navigator has displayed codes P1131 and P1151 on my scanner and say "Manfacter Contrls. fuel air meter". What does this mean? The spelling in the " " is how it actually reads.
Old 10-14-2003, 10:48 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It mayjust be extremely dirty. I would spray the small wires in the meter (located in the engine side of the air cleaner housing) with carb cleaner (engine off). Also check the wires to make sure that they are ok.
And I just wanted to say Welcome To FTE. I think that you will find a whole lot of useful info here.
Jimmy
Old 10-16-2003, 01:07 AM
wmcnally's Avatar
wmcnally
wmcnally is offline
pappa,
These codes indicate a LEAN condition in banks 1&2.
1) Clean your MAF and than disconnect your battery to reset your PCM. If the code(s) come back...
2) Do a search on the word "Lean". The posts will tell you to check for vacuum leaks. (unmetered air getting into your motor will cause a lean condition.)
If you need more help, don't hesitate to post again.
Good Luck,
Bill
Old 10-16-2003, 08:56 PM
aggiepapa72
Thumbs up
I found the problem. Thanks for the help. It was a deteriorated boot on the vacuum end of the PCV line where it connects on the back end of the throttle body.
Old 10-16-2003, 11:02 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Glad to hear you got it fixed
This seems pretty common, they must be using cheap rubber products these days.
Jimmy
Old 10-18-2003, 01:21 AM
re-engineered's Avatar
re-engineered
re-engineered is offline
The codes that you are speaking of concern the Ho2 sensors that are right after the exhaust manifolds. Usually accompanied by o2 sensor slow to read codes means its time to replace the heated o2 sensor.
Old 05-24-2010, 07:16 PM
marks500's Avatar
marks500
marks500 is offline
Same Problem... Help?
Didnt want to start a new post on this.. I just had My Check engine like checked and I had the same Codes showing P1131 and P1151. The Idles Rough but runs Fine, Gas Mileage seems to be worse... Where do I start? It seems like it could be a few things... Dont want to just throw Parts at it. Any help I would Appreciate! Thanks, Mark
Truck Info: 1997 Ford F-150 5.4L
tomtryshard
1997 - 2003 F150
07-13-2017 09:20 PM
elpadrino13
11-20-2010 06:14 PM
Wolf1200
1997 - 2003 F150
05-06-2009 01:28 AM
FordTrucks4Life
1997 - 2003 F150
02-20-2008 03:53 PM
98lincoln
01-03-2005 06:40 AM
Quick Reply: Code P1131 and P1151
