Keyless entry code for 2003 Explorer
Not sure on the 2003, but on the 99 its located in the back behind the panel that hides the jack on the driveds side.
You have to get a flashlight and look really carefully back in there to find it. Once I saw the module with the code on it I really had to strain to read the code. On the 99 the code is 5 digits.
Hope this helps.
Carlen
Hope this helps.
Carlen
If you can't find it the dealer was supposed to give you a card with the code on it. I suggest you go back to the dealer or call them and have the stock number the dealer had on the truck available. I bought my truck about a moth ago and the dealer handed me a little plastic card that had the manufacturer's code on it.
Door Key Code
I just got through this ordeal with my 2002 Explorer. Bye the way thanks everyone for there great ideas. But, it is located on the passengers side on mine. I had that whole truck torn apart on the drivers side and could not find it. Then a guy at work said it's buy the rear wiper fill. Which is on passenger side (on mine). Sure enough five minutes later I could open my door with the key pad!! It is a grey box about 6 inches long by maybe 4 inches wide. It has a 5 digit number stamped on a white label. That's it. It's just behind the door jam of the back passenger door. Just pop the back corner molding off, the molding where the back seat belt is, the molding back by the bumper(runs from side to side of the truck), then pop big pass. back panel loose(don't have to take it out) look in from the top just behind the back seat and you'll see it. Good luck.
jasnjen
26
02-27-2018 11:53 AM
FordTruckfan89
08-28-2016 03:52 PM
