Aerostar Ford Aerostar
Mustang Rims, Will it fit?!
Old 09-21-2003, 03:17 PM
BigTomMiller's Avatar
BigTomMiller
BigTomMiller is offline
Exclamation Mustang Rims, Will it fit?!
Alright, I am planning on buying rims for my 1992 Aerostar XL Extended 4.0. I have the stock steel 14" rims on it right now and I plan on buying rims for $125- 17" 3-spoke 1996 Mustang rims off of a 6-cyl 1996 Mustang, I need to know if these will fit on my van, fit in my wheel wells, and not hit my wheelwells when driving(rough and normal driving). I would just like to spruce up the look of my van with this, i hear that some mustang rims will fit but I would like a confirmation from the pros here. Thank you for you time.
Old 09-21-2003, 08:53 PM
68torino's Avatar
68torino
68torino is offline
Can't answer about the horse rims(I am curious) however if you have the hub caps and they are in good shape,would you care to part with them?
Old 09-22-2003, 02:17 PM
BigTomMiller
i would much rather part with the hubs, i want to put 17"s on the aerostar
Old 09-26-2003, 07:36 AM
BigTomMiller
alright, lets try this again, will they fit?
Old 09-26-2003, 09:42 AM
agelder's Avatar
agelder
agelder is offline
OK, according to discounttire.com, we have a 5*114.3 2?mm pattern/offset, as do the later 5-lug mustangs. Using this logic, the mustang wheels should fit. The only worry would be rubbing since the wheels are about an inch wider. Then again, on a stock height van, it MAY not be a problem. The good thing here is that you can pick up stock mustang wheel/tire combos for next to nothing since so many owners upgrade. I personally like the newer 5-spokes. I will look into this when I have to replace the tires next .
rel3rd
10-11-2020 09:23 PM
2000gpr
2004 - 2008 F150
04-09-2008 09:56 AM
Frenchy
04-22-2005 02:02 PM
fryoung
03-08-2005 06:50 PM
Quick Reply: Mustang Rims, Will it fit?!
