100,000 mile service
Spark plug replacement is one service recommended at 100K. A time-consuming process. Expect a $300 bill from a dealership. One plug is notoriously difficult to remove (#4, the rearmost plug on the passenger side). Ask for the old parts back and make certain you receive eight of the same plugs. Sometimes the techs "forget" to remove ol #4.
As an aside, you should be changing the transmission and transfer case fluid every 30K. Have the differential fluids ever been replaced? Brake fluid flushed?
Essentially, 100K is a good time to renew ALL fluids in the vehicle if they haven't been replaced/flushed on a regular basis.
ALL Fluids........................Tranny,Diffs,Oil,Che ck Brake fluid color.....
Spark Plugs.........ALL OF THEM..........................
Air Filter...................
PCV........................
Fuel Filter................
Check all your hoses for a "Spongy" feeling........If so replace them......................
Also, OVERLOOKED BY EVERYONE IS THE GOOD OLD SPARE TIRE.........DROP YOUR SPARE AND INSPECT IT IF IT NEEDS REPLACING DO SO...........Make sure the cable system works, and Lube the cable system.
