Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
- Why Do My Tires Thump?
Guide to diagnose trouble and recommended solutions
Dull thumping noise
Dull thumping noise
I'm stumped as to what the root cause of the dull thumping noise coming from the front end of my 1997 Ford Explorer XL...
For anyone that can help, here is what I know..
The noise is a dull thump, like a heavy gauge piece of steel under pressure being smacked with a hammer. It thumps with every rotation of the front wheels. It does not matter if I am in neutrul or drive nor if the 4 wheel drive is engaged. If I jack it up and spin the wheels by hand there is no unusual sound. The only thing I've really done is a visual on the front end and everything looks good.
I'm guessing it's a bearing problem because it only happens under pressure but I'm not swapping out a hub without someone else's opion first.
FOR THE LOVE OF GOD, HELP ME!!!!!
Dull thumping noise
I'm not very experienced with Explorers, but from my experience with other vehicles, the noise can be caused by a bearing problem, like the front differential going out. However, I had a similar noise on my Grand Cherokee and it ended up just being the front swaybars needing replacement from having a 3" suspension lift. Anyway, does the noise change with an increase in speed at all or when gradually slowing down? How many miles are on your Explorer? Good luck finding a solution to the problem.
Dull thumping noise
Thank you both. My Explorer has 70,000 miles on it. I did try replacing both front tires with the spare the other day and the noise did not go away or change location.... And to bad for me, my base model Exlplorer doesn't come w/ sway bars....
Dull thumping noise
Well, we can all be fooled... I swapped out each front tire w/ the spare and the noise never went away. Today after looking at it for a while and finding no trouble I sent both front tires to the rear end and went for a ride. The noise went with it. Turns out both of my tires have bad belts. Now it's back to NTB before the warranty expires... Thanks guys. I really appreciate the help...
Larry...
Hey, got a Volkswagen??? I'll help you out at:
WWW.BENTLEYPUBLISHERS.COM
Larry...
Dull thumping noise
for what it's worth...
I've got a '97 XLT with the same problem and after noticing BAD tire cupping on the front tires I installed new Gabriel shocks (this was last July). After a new set of tires (now with 17K miles) the noise/rumble is back. I just ordered a new set of Bilsteins for the front because the Gabriels were shot after 25K miles, and I don't do any off-roading. Car now has 115K and all in all has been pretty reliable.
Dull thumping noise
That's worth a bunch, the folks at NTB sited some cupping on the tires, they could not find any other tire trouble. The ride on my "Exploder" is getting a bit rough and new shocks are in it's future. Gabriel, well you get what pay for. Bilstien, same thing. They are the mother of all shocks and a wise investment.
Thanks for you input..
Larry...
Larry...
Rays auto
1999 to 2016 Super Duty
09-06-2016 10:49 PM
Nate Sabo
09-30-2015 01:03 PM
