7.3 Engine Block Heater
Old 08-10-2003, 09:03 PM
trakman's Avatar
trakman
trakman is offline
Just bought a used 2002 250 with the 7.3 Diesel. Looking for the so called "block heater" Found a cord that is plugged into the oil filter base. It then goes to the front bumper. What's the story on this? Nothing in the book refers to this heater assembly. I though that I would find a heating element in one of the freeze plugs but no such thing. Is this "oil heater" take the place of the coolant heater?
Old 08-10-2003, 09:40 PM
lipton's Avatar
lipton
lipton is offline
The heater is referred to in the 7.3L DI Powerstroke supplement included with your truck manual.
Old 08-11-2003, 07:12 AM
powerstroker250's Avatar
powerstroker250
powerstroker250 is offline
That IS the coolant heater. It goes through the oil filter housing into the water jacket in the block.
Old 08-11-2003, 07:30 PM
trakman's Avatar
trakman
trakman is offline
Powerstroker250...then what you are saying is that we are heating both oil and coolant with this one heater, right??????
Old 08-12-2003, 07:29 AM
powerstroker250
No, the heater is in the filter housing above the actual level of the oil.
Old 08-13-2003, 04:01 PM
Fitzydog's Avatar
Fitzydog
Fitzydog is offline
The block heater will basically keep the oil and the coolant warm to aid in an easy start. Ford says plug it in at least 2 hours before driving if weather is 30 degrees or below, but leaving it plugged in all night will not void nor hurt anything.
________________________
Aaron 99 F250 CC PSD 215,000 miles
Houston
I'd rather be stroked, than rammed!!
Old 08-20-2003, 11:18 AM
PSDLOVER's Avatar
PSDLOVER
PSDLOVER is offline
I have an 02 F-250 PSD and am totally unaware that it came with an engine block heater stock. I have spent some time underneath and have not noticed one. Where is it?
Old 08-20-2003, 01:26 PM
trakman's Avatar
trakman
trakman is offline
PSDLOVER...read my original post...tells you where I found mine..trakman
Old 01-16-2004, 01:31 PM
jefff's Avatar
jefff
jefff is offline
Are you saying the oil filter housing acts a block heater?
Old 01-16-2004, 02:31 PM
slc10844's Avatar
slc10844
slc10844 is offline
The oil filter housing is a heat exchanger with two sides to it. One side coolant circulates through and the other is engine oil. The assembly is designed to help regulate oil temperature with coolant when the engine is running. The block heater is mounted in the coolant side of the assembly. Since the block heater is used when the engine is not running, the heat is absorbed into the engine through the coolant.
Old 01-17-2004, 02:01 AM
horsecop's Avatar
horsecop
horsecop is offline
http://community.webshots.com/photo/...41737771wgGhll
Don't know if picture helps but the orange cable is the block heater. Follow the cable to the front of the truck. The plug is at the other end of it. If it's never been used it is still snapped in place. Hope this helps.
horsecop's Avatar
horsecop
horsecop is offline
Don't leave it plugged in all the time. Get a heavy duty timer and set it about four hours before you start your truck. The elements will fail so there's no need to burn it out if your not going to use the truck. It's a mess to change out. Easy, but a mess.
Old 01-05-2010, 03:09 PM
wjaaa701's Avatar
wjaaa701
wjaaa701 is offline
Just found the plug for my engine block heater after reading all the post on how to find out if I had engine block heater.
Thanks,
Will
Old 01-18-2010, 09:08 PM
jekoenig's Avatar
jekoenig
jekoenig is offline
7.3 PSD Engine Block Heater Cord
I have located the orange cord plugged into the oil filter base, but cannot locate anything behind or near the front bumper. Owners Manual indicates it should be near drivers side tow bar. Can't see it. Any suggestions?
Old 01-19-2010, 11:35 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
The orange wire changes to black as it travels forward to the bumper along the engine block. The cord end could be hidden behind the bumper on the driver's side as well.
Quick Reply: 7.3 Engine Block Heater
