Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
explorer keeps stalling
Old 08-09-2003, 08:43 PM
dmichael's Avatar
dmichael
dmichael is offline
Angry explorer keeps stalling
It doesn't happen often, but the Explorer keeps stalling when we approach a stop sign or red light. It gets to the point that we have to put the vehicle in neutral to start to SUV and in order for us to move!
Old 08-14-2003, 12:39 AM
1999EXP_XLT's Avatar
1999EXP_XLT
1999EXP_XLT is offline
Sounds perhaps like it could be the classic IAC (idle air control) Valve. When it gets gummed up with carbon it tends to stick and give you problems similiar to what you describe. What you want to do is remove it from atop the intake. You should see some black carbon deposits inside the valve. Spray some carb cleaner inside it and clean it out with something like a small toothbrush. I used Q-tips, but whatever works. But, send some more info about your truck's year and engine to be certain that this is your problem and I'm sure you will get a response.
Old 08-16-2003, 11:49 AM
flyncasafo's Avatar
flyncasafo
flyncasafo is offline
dmichael is probabaly right. My 2000 has been doing the same thing and I took it to the dealer today and they replaced the IAC. It fixed the problem for now. I have 47K on the explorer now. Hope this helps.
Old 09-02-2003, 10:22 PM
pn8baller's Avatar
pn8baller
pn8baller is offline
My 99 XLT 4x4 was doing the same thing. I have 160,000 miles on it and the problem just started. I pulled the IAC and cleaned it. It was pretty dirty. I then checked the unit and the system as outline in the Hanes manual. Everything checked out fine so I reinstalled it.
The whole process took about 15 - 20 min max.
So far so good.
Would probably be a good place to start.
Mark
auctionsagain
1999 to 2016 Super Duty
06-14-2020 01:53 PM
TaraLyne1010
06-28-2016 05:36 PM
Eve Bates
02-24-2015 06:42 AM
treeguy58
12-18-2012 05:39 PM
2kEB
04-15-2011 01:26 PM
Quick Reply: explorer keeps stalling
