What is a DPFE sensor, what does it do?
My '99 Ford Ranger is popping code. A handheld diagnostic machine shows the trouble code P1401. I looked it up and what I found is, that trouble code corresponds to a "DPFE sensor high voltage". Anyone have an idea what this could be, and where on the engine is the DPFE sensor?
Differential Pressure Feedback EGR - it's basically like a MAP or a barometric pressure sensor for your EGR system - it's there to measure the flow of EGR, but it's very troublesome IMO.
The sensor should be either a black or metal box about the size of a large zippo lighter with two vacuum hoses attached to it near the firewall. The hoses should go to your EGR tube between your intake and your exhaust manifolds.
I found the cheapest one at Pep Boys for about $60, but fords wants $90 or so and it's a bit better 'cuz it's plastic and doesn't deteriorate like the metal ones do.
edit: how am I new user with a join date of 2007, ive been breaking down in ford trucks since 1985
Hi guys,
I recently found this article which explains what is a DPFE sensor, symptoms and how to fix it.
SinisterSS
01-28-2004 04:12 PM
