1996 F150 CRUISE CONTROL
1996 F150
The cruise control was "intermittent" for a few days, and then it finally went out. I have checked the brake switch, and all connections. I have not removed the steering wheel yet.
If anyone has advice please send it to me.
Thanks,
Gene
1996 F150 4X4 Extended cab 153k miles. runs like new... except for the cruise.
Thanks,
Gene
Thanks for the e-mail.
Everything is working fine, except the cruise is not working.
I checked every fuse in the box in the cab.
There is a fuse box in the engine compartment although the fuses are not marked.
One of my friends had the cruise go out on his f150 and the problem was below the air bag on the steering wheel.
The cruise that I have has no vacuum lines and is totally electronic.
Thanks,
Gene
Thanks,
Gene
Got it fixed !!!!
The cruise was not working, but everything else was ok.
I checked the fuses. fuse 13 and fuse E were ok.
I checked the Brake switch on the brake pedal. It was ok.
I checked the redundant brake switch on the master cylinder. It was ok.
I took the servo out (2 bolts and disconnect the throttle attachment). Took it to a junk yard near my house. The junk man had a 92 F150 in the back of the junk yard. We pulled the servo off, and installed it on my 1996 F150. He charged me $75. Works like new.
Thanks for the help.
Gene
1996 F150 extended cab 4x4
Gene
kountzecobra
01-28-2016 06:10 AM
Adam Kemmerly
04-15-2004 04:48 PM
