wont idle below 1000 rpm....
02-22-2002, 01:24 AM
02-24-2002, 10:37 PM
on
i have an 88 f150 with a 300 i6 and it wont idle below 1000 rpm, even with the idle screw all the way out. anybody have any clue whats wrong? thanks,
mike
02-25-2002, 06:13 AM
I would guess that your distributor has turned, or more likely you have a vacuum line loose or off. I had a vacuum line off on my 460, and it would idle @ 1000-1100 rpm, found the leak and idle returned to 550-650
Marc
59-F100 4x4
91 F350 crew cab 4x4
02-25-2002, 07:33 PM
on
pull the iac valve off and see if it is stuck open. they get all gummed up and dont move too well anymore.
02-25-2002, 07:43 PM
on
While you clean the air bypass valve, also clean the throttle bores with a brush, solvent and a rag....it will idle way better regardless
Phil
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
