1978 - 1996 Big Bronco
Bronco payload and tow capacity
Old 07-26-2003, 03:53 AM
Cheap Monster's Avatar
Cheap Monster
Cheap Monster is offline
I got an 87 302 Eddie Bauer Bronco. Just curious what the advertised tow capacity and payload is for it. I did a search and couldn't find anything. Thank you much.
Old 07-26-2003, 01:41 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
You forgot to mention what transmission, and axle gearing your 302-powered Bronco EB has, but here is what I found out from the 1987 fullsize Bronco Owner's Manual : 302/ 5-speed/3.55:1 ratio(s) : maximum suggested trailer towing weight is listed as 4,000lbs. For the 302/automatics(C-6 & AOD)/3.55:1 maximum suggested trailer towing weight is listed as 7,700 lbs. For the 302/AOD/4.10:1 combination, suggested maximum trailer towing weight is listed as 8,000 lbs.
Old 07-26-2003, 07:09 PM
BroncoRoadKill's Avatar
BroncoRoadKill
BroncoRoadKill is offline
Are those #s close to or the same for 82 models. Mine has a 302, C6 tranny and 3.55 gears.
I usually haul a 1948 for 8N tractor w/ shredder, on a 16ft. tandem axle trailer that weghs about 1500 pounds or so.
I shredd fields on my spare time for a little exra money.
Bye the way, Fords never die, my tractor is living proof.
Old 07-27-2003, 10:14 AM
DeGideo's Avatar
DeGideo
DeGideo is offline
I'm not sure about the 1982 Bronco's tow ratings. Stock, I don't think the 302-2V would have the same towing capacities as the later EFI302s. I don't have a '82 Bronco Owner's Manual, but that's where you'd find the towing capacities for them. You can probably still buy one through Helm,Inc. (www.helminc.com),or pick up a used one on ebay. In the 1982 Bronco factory brochure, it lists a HD Trailer Towing Package, but doesn't list the equipment included in it.
Andy's Beast
2015 - 2020 F150
08-28-2017 07:25 PM
steuspeed
07-29-2016 04:06 PM
Onefortheroad
2017+ Super Duty
06-27-2016 02:33 PM
Ottawasteve
2015 - 2020 F150
03-20-2015 10:28 AM
PrinceValium
2009 - 2014 F150
18
10-29-2012 08:55 AM
Quick Reply: Bronco payload and tow capacity
