Econoline - Rear A/C blowing Hot out floor vents
Old 07-21-2003, 05:24 PM
TMCALLISTER's Avatar
TMCALLISTER
TMCALLISTER is offline
Question Econoline - Rear A/C blowing Hot out floor vents
My rear A/C is not working. It's blowing hot air out of the lower vents when the A/C should be coming out of the upper rear vents.
I had this same problem last year, and they replaced a broken blend door and actuator. The part was under $50 but the labor was huge.
I'd like to fix it myseld this time, but I DON'T KNOW WHERE TO FIND THE BLEND DOOR.
Can anyone point me in the right direction, or to a good book or web page?
Thanks.
Old 07-21-2003, 05:30 PM
bluezukiboy's Avatar
bluezukiboy
bluezukiboy is offline
any local parts store should have that part and a book to help you should check for vacum first at the rear control
Old 07-21-2003, 05:33 PM
TMCALLISTER
Thanks. I'm checking the parts store for a book after work tonight.
Old 07-21-2003, 07:18 PM
94van's Avatar
94van
94van is offline
You don't say what year you have. My '87 had the shut off valve to the rear heater allow hot water thru all the time. I replaced it, and problem cured.
Old 07-21-2003, 10:00 PM
TMCALLISTER
oops -- 1997 E350 Super Club Wagon V10 - 15 passenger
I picked up the Haynes Repair Manual, but no help.
Then repair note from last years repair said "Remove rear ac housing assembly to check for vent problem. Replace door and actuator"
I'm thinking it is behind the back left panels, where the rear ac unit is.
ballow97
1999 to 2016 Super Duty
02-17-2014 01:31 PM
ROBBINthaHOOD
11-18-2013 01:17 PM
coolfords
09-01-2012 07:59 AM
zmanmike
24
04-21-2008 11:18 PM
TMCALLISTER
Modular V10 (6.8l)
07-23-2003 03:13 PM
Quick Reply: Econoline - Rear A/C blowing Hot out floor vents
