Torque specs 1999 E350 rear axle
I'm in the process of replacing rear rotors on a 1999 E350 Xlt 5.4 V8. Upon removing the rear passenger rotor the parking brake was covered in grease. So I replaced bearings and seal on that side. I'm trying to find the torque specs for the spindle nut, caliper bracket bolts and the caliper bolts. I don't know if it helps any, but the axle code on the door sticker is 39. Thanks!
I don't know if this helps either but I found a service book for a Dana axle which may or may not be of any help. The book lists the ID axle tags if that helps.
http://www2.dana.com/pdf/AXSM-8941.pdf
Good luck!
jim
stbernard
1999 to 2016 Super Duty
09-15-2015 11:00 AM
