Anybody wanting to do a Leaf Spring Front End Conversion on a 97?
Old 07-28-2014, 10:13 PM
alnbrgr2014's Avatar
alnbrgr2014
alnbrgr2014 is offline
I have a conversion kit for a 97 f-150. Not going to say it is complete, but at least most everything is there. Have a stack of parts that were purchased to do a leaf spring conversion on a 97 front end. I'm not sure what all is required for this conversion, so I'm not sure what all is there or missing. Wondering if someone can tell me what all should be there vs. what all I have and what a kit like this should sell for. Got the truck halfway through a lift project, but the front hadn't been started yet. Lots of fabrication parts, brackets, new leaf springs, shackles, shock mounts, bushings, etc. I plan to take the rear end back to stock as it's been fitted with much larger springs. I'll take some pics and post as quick as I can, but really need to figure out what to do with all this stuff.
Old 07-28-2014, 10:57 PM
88-150's Avatar
88-150
88-150 is offline
Just tossing my two cents as this has been something i've been wanting to do myself, but I'm not 100% sure the front can be converted since it's IFS. Only way I could see it being done with a straight axle like a D40 or D60 and there's a company(can't think of it off the top of my head) that sells the complete kit with the axel, leaf springs, mounting hardware, etc.. if i remember it I'll post it.
Old 07-28-2014, 11:18 PM
alnbrgr2014
This was intended to be a solid axle conversion with dana 60 rear and dana 44 front, to the best of my knowledge.
Old 07-29-2014, 05:28 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
These truck drive very smooth with the IFS... I would not put the solid axle without a VERY GOOD REASON.
Old 07-30-2014, 12:45 AM
88-150's Avatar
88-150
88-150 is offline
My mistake. Thread came off as attempting to convert IFS to something using the IFS. Anyhow, this site might help you so you know what other kits have in them so you know if you need anything. Bolt In Axles - Complete Axle Assemblies - Axle Housings
Vertrees
15
06-29-2015 03:51 AM
PAwhiteboy
06-11-2012 11:01 PM
FordmanShane
04-18-2010 08:36 PM
lifted ssx
1983 - 2012 Ranger & B-Series
11-02-2003 04:24 AM
Quick Reply: Anybody wanting to do a Leaf Spring Front End Conversion on a 97?
