Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
'67 F600 Tune Up Specs
Old 07-26-2014, 06:40 PM
dbreienrk1's Avatar
dbreienrk1
dbreienrk1 is offline
I recently purchased a '67 F600 with a 330 2V Medium Duty FT engine and a 4-speed manual transmission. It's a pretty stock under the hood and it's a weekend vehicle so no high-performance parts or setup is needed.
Does anyone know the specs for a complete tune-up? I read the air/fuel ratio should be 13:1 vs the standard 14.7:1...any thoughts on this? Also, what spark plugs would you recommended I install? Ideally, I'd like to know...
Spark Plug Gap
Point Gap
Cam Angle
Ignition Timing BTDC
Firing Order
Idle Speed RPM
Fuel Pump Pressure
Compression Pressure
Old 07-26-2014, 08:55 PM
gangstakr's Avatar
gangstakr
gangstakr is offline
Do you have the 67 hood emblems for the F600?
Old 07-26-2014, 09:02 PM
dbreienrk1's Avatar
dbreienrk1
Are you referring to the chrome "FORD 600" emblems on the left and right fenders? Yes, but not really relevant to what I was asking...
Old 07-26-2014, 11:41 PM
orich's Avatar
orich
orich is offline
Plugs gap .030
points .017
dwell 26-31
Timing 10 BTDC
Idle speed 525 rpm stand tranny, auto 500
Compression 140 psi
Plug type BTF-31
Hope this helps!
Orich
Old 07-26-2014, 11:46 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,591 Likes on 1,296 Posts
[quote=dbreienrk1;14535930]............ I read the air/fuel ratio should be 13:1 vs the standard 14.7:1...any thoughts on this? .....................
They like 'em to run rich to help keep them cooler. Lean it out and combustion temps start to go up. Lean it out and run it WOT all day (as you may have to with a 330) and you might hole a piston.
Gas was cheap, improved pistons and other combustion chamber changes etc were expensive.
Did you get a 2 speed axle?
Old 07-27-2014, 10:03 AM
dbreienrk1's Avatar
dbreienrk1
Yes, but I'm not using it to haul so it won't really be used.
Thanks for the info on the air/fuel ratio.
dbreienrk1's Avatar
dbreienrk1
Originally Posted by orich
Plugs gap .030
points .017
dwell 26-31
Timing 10 BTDC
Compression 140 psi
Plug type BTF-31
Hope this helps!
Orich
Thank you! Much appreciated.
Old 07-27-2014, 03:48 PM
85e150's Avatar
85e150
My dad would shift 2-3-4 in low and used the high rear axle setting as another gear when empty. Easier on the clutch maybe.
rutherj
401, 477, & 534 SD Engines
09-02-2017 06:49 AM
Ekkehard
17
11-02-2010 09:19 PM
smbikes
09-06-2009 09:36 PM
jdoyle
12-02-2006 12:37 PM
daveengelson
01-12-2006 06:44 PM
Quick Reply: '67 F600 Tune Up Specs
