PCV
Old 07-25-2014, 12:26 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
PCV
I looked on ebay and found a PCV valve with a threaded male on one end and a male hose barb on the other, very simmilar to the one Chevrolet used on my '63. This one on the package it lists it for a '61 to '62 Ford/Mercury 292.
Question I have is how does this hook up? Could it be used on a older 292?
I ask because I would like to convert my '56 292 to use a PCV valve if possible. I dont drive much, barely put 2,500 miles on my daily driver in a year, but Id still like to be able to have confidence in going 3,000 to 6,000 miles between oil changes on this engine.
I recall reading that in california they did it by threading a PCV valve into the side of the road draft tube then hooking to a vacuum source. But if 61-62 came with them standard I wonder how they hook up cause as far as I know the 292 Y8 was the same up till 63/64, just the intake changed.
Old 07-28-2014, 06:54 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Here's a pretty good discussion on Y Block PCVs from the HAMB. Y-block PCV | The H.A.M.B.
Olafs 7.3 ex
05-08-2019 09:06 PM
Tomget
05-24-2015 09:21 PM
68cabby
12-24-2012 02:09 PM
madrox
12-17-2009 06:09 PM
jaye
03-15-2006 02:41 PM
Quick Reply: PCV
