A couple of issues
Old 07-22-2014, 10:54 PM
87diesel's Avatar
87diesel
87diesel is offline
A couple of issues
Alright I have a 97 f150 v6 5spd 4x4 i bought about a month ago. I like it but it's has some problems since i got it. The first one is how most of the time when i start it it'll barely crank and when it starts, it will run rough for a few seconds then smooth out. Usually when it's cold. My other problem is when i go to stop, and I'm on the brakes pretty hard, the rear brakes will let go and then lock up on me. Thanks
Old 07-22-2014, 11:03 PM
87diesel's Avatar
87diesel
87diesel is offline
Also i had a thread on the first problem like a month ago and they said to spray a fuel injection system cleaner up into the intake because the IAC valve may be gummed up or something like that. Is that it or could it be something else? And what cleaner would you recommend? Thanks.
Old 07-24-2014, 11:10 PM
MJE426's Avatar
MJE426
MJE426 is offline
For the slow cranking I would start with the battery and alternator. Have them checked, if they check out, then I would look at the starter and the wiring. One or more of those components could cause slow cranking.
The rear brakes could be several things, you need to pull the drums off and inspect them.
dockrocker
08-26-2012 09:43 AM
wagon burner
1997 - 2003 F150
03-23-2009 07:24 PM
redrocket98
1997 - 2003 F150
03-15-2008 08:29 PM
Matt_W
1997 - 2003 F150
07-26-2003 11:02 PM
Paul_W
04-21-2000 07:11 AM
Quick Reply: A couple of issues
