I have an 03 F150 supercrew FX4 and I noticed today that my ABS light has came on and won't go off. I know I need to replace the front pads and rotors, but what will cause the light to come on?
the light can come on if any of the sensors have a fault in them. a bad enough wheel bearing can cause an ABS light. a problem with the module itself. if you have a scanner that reads ABS codes look at the codes and see what wheel it says that way you can at least have a starting point.
