01 e350 dana differential question
Guys i have a couple of question. My 01 ford E350 diesel van has carrier bearing problems and i am having a heck of a time finding a carrier gear side thrust shim. I also can get my hands on a 2000 dodge 2500 dana complete rear end with 411 gears with posilock for 125 bucks. I would love to buy the dodge dana but do not know if the fords rims would fit and would my pinion yoke off van fit the dodge dana pinion shaft. My carrier on my ford dana is in bad shape as far as bearing fit on ring gear side ( bearing does not press on hard , real easy).. My tag on rear says 410 VYC25 and bottom of tag says Guys i have a couple of question. My 01 ford E350 diesel van has carrier bearing problems and i am having a heck of a time finding a carrier gear side thrust shim. I also can get my hands on a 2000 dodge 2500 dana complete rear end with 411 gears with posilock for 125 bucks. I would love to buy the dodge dana but do not know if the fords rims would fit and would my pinion yoke off van fit the dodge dana pinion shaft. My carrier on my ford dana is in bad shape as far as bearing fit on ring gear side ( bearing does not press on hard , real easy).. My tag on rear says 410 VYC25 and bottom of tag says V605522-6. any idea what i have cause local ford dealer does not. .................thanks for any info you all can shed on this.
62FE4x4
09-12-2017 03:05 PM
mudder460
06-12-2011 02:03 AM
79 E350 rescue
07-29-2006 10:13 PM
79 E350 rescue
07-18-2006 09:21 AM
