Where does this wire go????
Old 07-20-2014, 04:30 PM
mchemical's Avatar
mchemical
mchemical is offline
My son and I changed the spark plugs in my 2004 F-150 Lariat with the
5.4 Triton V8,v3 engine. Thankfully, we got all 8 plugs out without breakage.
We do have a problem. There is an extra wire that we do not know where
it goes. This red wire come out of the coil/plug harness near the fire wall.
The end of the wire had a trumpet appearance and was about the size of
a dime. In the center was a round object about 3 millimeter in size. Over
all this terminal was very clean. The truck seem to be running fine.
Could anyone tell me where this attaches.
Thanks
Old 07-21-2014, 01:56 AM
ojai150's Avatar
ojai150
ojai150 is offline
Thanks
Are you sure its a wire , and not a small hard vacuum hose ?
Old 07-21-2014, 03:42 AM
mchemical's Avatar
mchemical
Wire.....vaucum hose?
No, it is not a vacuum hose.
Thanks for asking.
Old 07-21-2014, 05:08 AM
mchemical's Avatar
mchemical
where does it go
Thanks for asking.
Well, I really do not know for sure. It just does not appear to be a vacuum line.
Old 07-21-2014, 06:04 AM
David7.3's Avatar
David7.3
David7.3 is offline
What side of the motor is this on, Is it just s single wire? I have a connector that hooks to the OPS under the intake, and some tritons have there knock senors mounted under there and more info and I will look under my hood again and see.
Old 07-21-2014, 06:14 AM
David7.3's Avatar
David7.3
David7.3 is offline
I checked my 04 again, the only thing I see on the passenger side is the red vacuum line that goes from the intake to the purge valve (MOUNTED ON FIREWALL) to the vacuum can.
Old 07-21-2014, 07:54 AM
mchemical's Avatar
mchemical
Red Wire
Thanks Dave7.3 I will look and see if I can find it as you suggest.
Old 07-21-2014, 12:05 PM
ojai150's Avatar
ojai150
ojai150 is offline
I would bet it is the 2nd part of the vacuum line that goes from the back of the intake on the passenger side to the fuel pressure valve
Old 07-22-2014, 10:21 AM
mchemical's Avatar
mchemical
Now to find the loacation on the firewall
You are exactly correct Dave7.3. The trumpet looking part is part of the
purge control valve. ( I saw the part in parts catalog)The redline is a vacuum line.
Now to find this purge valve. Could you give me a little more instructions
on it exact location. Then I will have the job done.
Thanks Dave7.3
Old 07-22-2014, 10:53 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
That red vacuum line goes to the 4wd hub solenoid and is not plugged into anything on 2wd trucks. The purge valve is on the driver's side next to the brake booster
Old 07-22-2014, 11:05 AM
mchemical's Avatar
mchemical
Thank you for your reply.
kaysystems
Large Truck
06-18-2017 06:01 PM
82_F100_300Six
07-01-2008 06:28 PM
E150
Electrical Systems/Wiring
11-16-2005 04:30 PM
Greywolf
Garage & Workshop
15
10-08-2004 10:36 AM
kf4zra
Aerostar
06-15-2004 06:04 PM
Quick Reply: Where does this wire go????
