'99 F250 LD 4X4 5.4L Cylinder Head....
Hey guys, I have a 1999 F250 LD 4X4 w/ 5.4L and over 220,000 miles.
Problem, engine developed a pin-hole in the driver side cylinder head just under the thermostat housing of the intake manifold and was squirting water into the fan.
Quick fix, was to patch the outside with J.B. Weld Metal. About a year later I had to remove the intake manifold to replace a IM gasket (I also replace the water pump to heater pipe that run thru the "valley")... I then reinforced the "patch" from the inside since I could reach inside with the IM removed. I discovered the wall of the effected water channel was paper thin due to corrosion. This was about 4 years ago.
Just the other day I found coolant under the truck and the "valley" filled with coolant. I thought the water pump to heater pipe went bad again. But I soon found the leak was coming from another hole in the same cylinder head under the thermostat housing.
So my options as I see them are:
1. Replace cylinder head...my concern is the effect of 1 "tight" new head and 1 "loose" old head on the engine.
2. Replace both heads...my concern is if there is corrosion in 1 aluminum head, where else is there corrosion?
3. Crate motor replacement $$$
Any thoughts and/our advise will be greatly appreciated. Can the heads be changed relatively easy while engine is in truck?
You did the intake so you know things are tight in there. How long do you plan on keeping the truck?
I would say that one head wouldn't cause a problem but you don't know whether or not the other is corroded as well.
If it is longer term then a crate or rebuilt motor might be the answer since it would require the same if not less effort to swap out than the head. $$$ also comes into play here as well whether you do the work or not.
VIN Decoder - Ford Truck Enthusiasts Forums
The Ford Truck 17-Digit Vehicle Identification Number (VIN) Decoder
It's the 8th digit of the Vin number. The first link will decode the whole Vin for you, or you can look it up on the second link.
Sore Knuckles
01-05-2011 09:18 AM
sdloe
12-15-2006 04:33 PM
chili97
05-26-2004 10:20 PM
