272 Smoking when shut off?
I rarely open the hood of my 56 F100 after driving because it's such a PITA. But yesterday I opened the hood after taking it for a 5 mile run. There was a pretty fair amount of smoke coming from the ole 272's oil filler cap. I started the engine again and no smoke, stopped it and it started smoking again. The truck has a road draft tube (no PCV) and both the screen in the road draft tube & the filler cap are new (less than 100 miles).
Is this an indication something's wrong? Any opinions or solutions?
Not sure. It ran well 25 years ago then sat until last year. I changed the oil & Filter, replaced the fuel pump, road draft screen and oil cap, cleaned out the fuel tank & carb. Started right up. Ran it for about 50 miles and changed the oil and filter again. Seems to have plenty of power, starts right up. Has a 4 barrel ford manifold with a 390 CFM Holley.
It only smokes after I shut it off. Been thinking about changing over to a PCV system but was afraid the smoking might mean that the ole gal is getting too hot. I did have the radiator repaired and changed the water pump, hoses & thermostat.
Also added Petronix electronic ignition and coil.
Your engine will love you for it. Good for the environment also.
Zwalters
10-02-2013 08:09 PM
