starter not engaging/check guages displayed
Old 07-13-2014, 01:05 PM
tompkinsmi's Avatar
tompkinsmi
tompkinsmi is offline
I just put a brand new engine in my 2004 f-150 4X4. Truck ran fine for two days. Yesterday I started the truck as usual put it in reverse. As I was backing up it just stopped running no warning nothing just stopped. All electrical still working fine guages radio etc. When I turn the key I get nothing no starter nothing. The security light continues to flash slowly even when the key is turned on. Basically the best way I can describe it is. The truck is acting like it is in gear when I turn the key any help would be great. And the odometer reads check guages
Old 07-15-2014, 04:33 PM
1969furd's Avatar
1969furd
1969furd is offline
neutral saftey switch?
Old 07-18-2014, 12:29 PM
TallEddie1981's Avatar
TallEddie1981
TallEddie1981 is offline
I had just about the same thing happen to me (going to make a post about it soon). Went out to start the truck and nothing, odometer said check gauges. Don't remember what the security light did. Turned out to be a break in the ground wire for the PCM. If you have a scan tool, plug it into the OBD port and see if is reads anything. When I plugged in my scan tool, it said turn key to the run or on position. So basically the PCM wasn't powering up. The computer actually starts the truck, not the key. The key just sends a signal to the computer to start the truck. In fact you don't need to hold the key to start it, just turn it to the start position for a second and let go, and the engine will contine to crank until it starts.
Old 08-16-2014, 02:17 PM
tompkinsmi's Avatar
tompkinsmi
The mechanic pinched my number 6 injector wire in between the manifold. So a thousand dollars worth of dealership so time and problem fixed
Old 08-17-2014, 02:20 AM
ojai150's Avatar
ojai150
ojai150 is offline
It sure doesn't work that way on my 04 5.4. , you have to hold the key on until it actually starts
IHateCommieCars
11-09-2015 05:22 PM
97powersmoke
04-12-2014 11:42 AM
kencrystaljen
16
01-02-2012 08:57 AM
70T351W
06-04-2008 08:17 PM
rustydog78
12-20-2005 04:08 AM
Quick Reply: starter not engaging/check guages displayed
