An interesting suspension arrangement
Old 07-12-2014, 08:01 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
found this cruising craigslist. Wonder how that thing rides and handles.
1949 Ford F1 Rat Rod Project
Old 07-12-2014, 08:33 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
What an abortion. I believe I am being kind. I am amazed that someone will put new tires on a project that is no where near road worthy.
Old 07-12-2014, 09:40 PM
mgargiullo's Avatar
mgargiullo
mgargiullo is offline
I'd give him $500 and he can keep the tires. Whoever setup that front end should have their tools taken from them before they hurt themselves.
Old 07-12-2014, 09:51 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
I see about 12 laws of automobile physics being broken
Old 07-12-2014, 10:14 PM
AXracer's Avatar
AXracer
AXracer is offline
I highly doubt it would ever drive or handle safely. There is too much wrong with that to even give it semi-credibility by criticizing or discussing it. Looks like they simply turned the chassis upside down!
Old 07-12-2014, 11:13 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
New meaning to the term "axle flip"..........
The word "deathtrap" also comes to mind.
Old 07-13-2014, 07:48 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is online now
Phantom of the Phorum
There are a few guys that do a lot of engineering and spend a lot of time, money, and effort to get their Rat Rod's suspension geometry "Right". Then there are the other 98%. Guess which category this one falls under.
Old 07-13-2014, 08:05 PM
Giesterfarher™'s Avatar
Giesterfarher™
Giesterfarher™ is offline
Looks like all he did was turn the frame upside down and mount the cab on it. If so, it's salvageable.
Old 07-13-2014, 08:53 PM
EffieTrucker
Looks like they did re-stack the spring packs. I wonder if they bent the axle and flipped the spindles right side up to correct the camber angle?
Never mind. I can see in the pic the tie rod arms are on top.
Old 07-13-2014, 08:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
What's sad is that there are two other cars/trucks in the background, undoubtedly waiting for similar treatment...
Old 07-13-2014, 09:00 PM
theGman's Avatar
theGman
theGman is offline
Just when you thought you'd seen it all...
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
The frame isn't flipped, just the entire front suspension.....including the spring hangers.
The builder obviously has no clue about scrub lines, kingpin inclination, ackerman angle, scrub radius, etc, etc. Or just wanted to look "kool".
Hopefully someone doesn't buy that and try to put it on the street like it is......
Old 07-13-2014, 10:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I can't quite get my head around it, but wouldn't the steering be reversed now?
Old 07-13-2014, 10:52 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Scott, I have never herd of most of those things you just mentioned, but one dosn't need to, too know that thing is just wrong, and unsafe. The one good thing about this rat rod is, because of it being posted, now I will look up, what scrub lines, scrub radius, and ackerman angles are. I always learn something when I log in to "The University of FTE"
Old 07-13-2014, 11:24 PM
EffieTrucker
No, the drag link pushing the arm away will still result in the wheels steering to the left.
The problem is it's now a foot above the steering box. Talk about bump steer.
If you flipped the pitman arm to make up for the flipped axle, that would reverse the steering.
Quick Reply: An interesting suspension arrangement
