no over drive 07 f150 v8 4.6
Old 07-12-2014, 12:29 AM
sitdown318's Avatar
sitdown318
sitdown318 is offline
i had to replace center support snap ring and some friction plates when put tranny back together have no od even when i switch it off on shifter no change drive just barely goes and engine reves way hi
Old 07-12-2014, 03:06 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
How is 1st and 2nd? Did you reseal all of the drums and use seal protectors? Did you replace the direct clutch sealing rings? Did you torque the valve body bolts and make sure the EPC is installed correctly? Did you flush the torque converter and cooler?
Old 07-12-2014, 03:49 PM
sitdown318's Avatar
sitdown318
No sir I didn't realize I needed to do that I just replace that snap ring and the friction plates,how do I flush the converter and cooler
Old 07-12-2014, 05:09 PM
70f100longbed
Which friction plates did you replace and why? Were they burnt?
RiverDog2
02-08-2019 10:18 PM
erniek70
1999 to 2016 Super Duty
06-23-2017 08:06 AM
Davis5149
1997 - 2003 F150
06-10-2015 05:47 PM
Aireeek
09-17-2007 10:10 PM
maverickgear
Aerostar
10-25-2003 06:50 PM
Quick Reply: no over drive 07 f150 v8 4.6
