Slightly different blend door acuator problem
Old 07-11-2014, 08:53 AM
ctvarner's Avatar
ctvarner
ctvarner is offline
'08 150 SCREW. I had the common problem where the heat was either full hot or full cold, nothing in between. Replaced the actuator and it seemed to be good. A few weeks or months later, the actuator started chattering on startup, like it was stripping its gears. Lifetime warranty, replaced it again... and the second new actuator does exactly the same thing. (I am 100% certain I did not remove and replace the same one.)
So other than a third failed actuator, what else could the problem be?
Old 07-11-2014, 07:05 PM
danorules's Avatar
danorules
danorules is offline
Did you disconnect the neg battery cable? You can ruin the actuator if it gets power before being properly installed
Old 07-11-2014, 07:09 PM
ctvarner's Avatar
ctvarner
ctvarner is offline
I did not, but I also did not start the truck or even put the key in the ignition until the installation was complete.
Old 07-11-2014, 07:24 PM
danorules's Avatar
danorules
That may be your issue....I know every repair says to disconnect the battery, but this one really means it. If I remember correctly the actuator centers itself and if it's not properly installed before getting power, it will burn itself out
Old 07-11-2014, 07:27 PM
ctvarner's Avatar
ctvarner
ctvarner is offline
Well, back to AutoZone I go, and I'll disconnect this time. Thank you.
Old 07-11-2014, 07:41 PM
danorules's Avatar
danorules
Good luck
Old 07-13-2014, 08:56 AM
ctvarner's Avatar
ctvarner
ctvarner is offline
Replaced again, with the battery disconnected this time, and so far so good. We'll see what happens. Thanks!
Old 07-13-2014, 03:18 PM
ctvarner's Avatar
ctvarner
ctvarner is offline
I spoke too soon! After four or five starts where it worked perfectly, the new actuator started making the "stripping gears" noise again. Crap!!
Old 07-14-2014, 08:14 AM
TallEddie1981's Avatar
TallEddie1981
TallEddie1981 is offline
Here is a good video about replacing the actuator. Now sure exactly what years this applies to, but this guy says you need to remove the HVAC fuse, the fuse number is in the description of the video.
Old 07-14-2014, 10:14 AM
ctvarner's Avatar
ctvarner
ctvarner is offline
possible explanation...
Thanks. Pulling the fuse would be a good idea, as it would save the radio presets, engine computer settings, etc, but I disconnected the battery, rendering the fuse irrelevant.
Both replacement actuators were made by Dorman; their website lists two different actuators for this vehicle. Dorman tech support says they have different actuators with the same body and connector, but different range of motion, and having the wrong one installed can cause this clicking noise as the motor tries to move the door beyond its physical limits.
I'll work with Dorman to figure out which actuator is actually correct - I'll bet a nickel it isn't the one I have installed - and we'll go from there. Stay tuned!
Old 07-14-2014, 11:20 AM
ctvarner's Avatar
ctvarner
ctvarner is offline
And for what it's worth, my clicking is very different from the one heard in the video. Where the video clicks are heavy and one at a time, "CLICK. CLICK. CLICK.", my individual clicks are lighter and much faster,
"clickclickclickclickclick".
Old 07-14-2014, 11:44 AM
ojai150's Avatar
ojai150
ojai150 is offline
Was there a part number on the original part , to match up ?
Old 07-14-2014, 12:04 PM
ctvarner's Avatar
ctvarner
ctvarner is offline
Dorman says the two actuators listed are for the temperature blend door and the mode door (console vs floor etc), and I have the correct part for the temperature. Suggested pulling that fuse (or disconnect battery again) for a few minutes to make it re-calibrate itself. Here's hoping.
Old 07-14-2014, 03:56 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
The blend door itself could be binding.
Old 07-14-2014, 05:25 PM
ojai150's Avatar
ojai150
ojai150 is offline
That's a good possibility. Is there anyway to move it manually ?
rkedz
2004 - 2008 F150
12-17-2009 08:41 PM
jdew1920
09-25-2006 07:45 AM
jvorrius
09-19-2003 09:29 AM
Quick Reply: Slightly different blend door acuator problem
