Carburetor Identification
Old 07-06-2014, 06:26 PM
AberrantGenus's Avatar
AberrantGenus
AberrantGenus is offline
Hi, I just bought a 67 f100. It has a 460 out of a 71 crown vic or grand marques. Can anyone tell me what kind of Holly this is so I can get a rebuild kit? It is stamped with List-3310-2 2D45. Not sure if that is a "D" or a "0". Also in the second picture you can see an aluminum tubed wrapped in a braded cotton of some sort. It comes out of the carb and loops around the exhaust manifold and doesnt go anywhere. What is the purpose of it?
Old 07-06-2014, 06:31 PM
AberrantGenus
oh sorry. it is a Holly
Old 07-06-2014, 09:17 PM
redroad's Avatar
redroad
redroad is offline
The heat tube supplies hot air to the choke .. Some electric chokes although electric still require a hot air source .. Your carb's model number is a 4160 .. Get a Holley brand kit for a 4160 don't use any other substitute .. It does matter
The 3310-1 is actually a 4150 carb, because its got a metering block (removeable jets) on the secondaries. The 3310-2 through 6 are 4160 style, because they use a metering plate for the secondaries (non-removeable jets).
http://www.holley.com/data/Ads/3310page.pdf
Old 07-06-2014, 10:01 PM
AberrantGenus
Thanks for the info redroad. So, for not other reason than it is ugly, is there something else I can do with the heat tube? the outside and interior of the truck are almost perfect. I would like to get the engine compartment to match.
Old 07-06-2014, 10:33 PM
redroad's Avatar
redroad
redroad is offline
You can get Choke Conversion Kit PART #: 45-223
Holley Performance Products Choke Conversion Kit 45-223
http://www.holley.com/data/Products/...R7972-4rev.pdf
Old 07-09-2014, 09:55 PM
AberrantGenus
Got it all done. Thanks for the help. I cant believe what a difference a carb kit makes.. 100% improvement.
Old 07-10-2014, 07:26 AM
redroad's Avatar
redroad
redroad is offline
excellent !
changosanch
07-13-2019 06:28 PM
Remedy2805
02-06-2016 11:01 AM
berry1234
07-08-2015 06:00 PM
1930 Dodge
89
01-08-2013 12:33 PM
Roller150
04-07-2011 01:47 PM
Quick Reply: Carburetor Identification
