What if...
#166
" Man oh man, what a day. I got tutored in cleanroom diesel work. I had no idea how clean I needed to have those holes. Rich got #2, the only one leaking, sparkling clean and we seated the new cup. Its curing now. We'll give it a pressure test tomorrow and button it up. This clean thing is the issue - I'm not doing it well enough."
It kinda states why he may have had so many troubles with his injector cups the first six times. I admit that it would be testing having to deal with the issue as many times as he did but it goes to show attention to detail can be the culprit maybe more often then not. Rich, good on you for helping him out.
#167
#169
#170
#171
I'm curious about the new Cummins 6.7L, but mostly about the crap they hang on it. It's the cling-ons with the Ford that bother me, in regards to the new diesel engines. Europe has found a way to make small diesel engines that meet emission standards - without so much post-engine whiz-bang. I don't yet know how this translates in scale, like for OTR trucks.
#172
I know the Ford 6.7's are very nice vehicles. A good friend of mine has an 09 Dodge and he loves it. His is a bone stock highway queen. Most of the time he only tows his Airstream. I drove it when he got it, and it certainly isn't lacking for power! Gets very good mileage, he drives like an old man. I was quite shocked how quiet it is inside his cab while driving it. He also hates the idiots that drive around with the tow mirrors flipped up while not towing, but are very nice when you do tow.
#173
#174
EFI live is available for the 6.7 cummins. Honestly I don't know what tune is loaded to my truck but it's so nice that I do not want to change it.
I have driven the 6.7 PSD and I'll admit it is a very nice and powerful engine that obviously was intended to pull. While not pulling I felt it was lacking, mileage was horrible and the transmission strategy was down right annoying to me personally.
My cummins is illegal to drive (I know) because of the dpf/egr delete, it has an aftermarket turbo because the stock vgt is a known weak point though the stock exhaust brake is favored highly I do not have one. My turbo is a very small 62/80 that lights almost instantly. The worse mileage that I have recorded to date has been 16 and and the best has been 17.76 mpg with spirited driving 70% city driving. I've noticed the mileage does not change much no matter what I'm doing with the truck. That's also hand calculated if I listen to the overhead I would never get worse then 19 and a best of 26.7
My truck stacked up to a stock 6.7 PSD is in no way a fair playing field. The stock transmission behind the cummins is good but not great. The shifting strategies are geared for driving and mileage more then pulling. With 4:10 gears at 70 mph with 35s my rpms are roughly 1600, that is not ideal in most situations. 5tha and 6th gear come way to early. The PO of my truck had a RevMax 850 installed which is a bulletproof transmission that will handle 850 horsepower. My truck is a pull truck that has a side benefit of a lot of power.
Adding power with my cummins is a pricy deal. Not because it's hard to make power infact it's just the opposite problem. It's so easy that if the right precautions are not taken things come apart easily.
#175
I know the 6.4's can make power pretty reasonably. I think they may have the edge over the 6.7's right now. I'm sure part of that is the aftermarket has been playing with that engine longer than the 6.7. My buddy claims to have gotten over 25mpg out of his stock 6.7 Dodge. His brother has a Dodge 2014 6.7, top of the line truck. It is basically a top of the line SUV with a pickup bed. Too nice of a vehicle to use as a truck in my opinion, which he doesn't.
#176
The 6.4s are no joke and I thought very hard about getting one of those too but with those truck the price is still a little far fetched in my mind and having to get rid of the emissions things on those engines are also a must for the utmost power, reliability, and mileage. 500 Hp out of the 6.4 or 6.7 is the low end of power. I'm around a conservative 500 Hp though I know it's more then that but I say 500 because I have no dyno results and no interest in getting one either.
I also can't stand when guys leave the tow mirrors flipped up.
The main reason that I went with my truck is because I knew what was done to it, no expence was spared anywhere that I could tell so I took the chance based off of what I could tell. Everything that I would do to the truck was already done. The weak points were addressed and only top of the line parts were used. When I bought it I had no idea about the transmission that was in it. It turned out my hunch was dead on when I found out that there was an $8k transmission behind the engine.
I have no regrets in the decision I made and I do not miss my 7.3 often. If anyone has any questions for me please ask, that's why I posted here and brought this thread back to life.
#177
I was under the impression that the automatics behind the cummins were top notch. I recently learned that I was wrong. Apparently they have issues just like the 7.3 guys do that turn up the power.
I saw a Dodge a year back that I considered buying. It was a flood/insurance truck, and the shop that had it was just getting started on it. The back end was under water, but the water line was only a couple inches above the oil pan as far as the motor went. The shop owner figured that a thorough cleaning of that truck, flush engine, tranny, and differentials, drop the fuel tank and clean, flush the lines, and you could have a good truck for less than half the price of a new one. It was a 2013, with less than 10,000 miles. Water did get into the cab, but only a couple inches. The seats were fine.
#178
Its not unheard of for them to swap a 4R100 into even the newest trucks.
