Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F700 GVCW ??
Old 07-01-2014, 04:03 PM
challenger2k's Avatar
challenger2k
challenger2k is offline
F700 GVCW ??
Does anyone know the gross vehicle combination weight rating (GVCW) of a '92 F700 dump, (429 gas automatic trans).
Should I be able to tow a 6K trailer loaded with a Case 580SL (18k lbs), or a Komatsu PC100, (24k lbs)? It feels a little weak, with poor accel., especially on a light grade.
What kind of gas milage should I get. empty vs loaded?
Old 07-02-2014, 02:04 AM
1969furd's Avatar
1969furd
1969furd is offline
gas milage 4-5 MPG loaded ford big blocks (460's) only got 10-12 in a 1 ton truck so you might get 8 empty
Old 07-02-2014, 07:54 AM
gandrimp's Avatar
gandrimp
gandrimp is offline
I'm not sure a trailer that only weighs 6k will safely haul 18k much less 24k.
My trailer weighs 7.5k and is only rated 20k, that said, I have had 24k on it but I was left wanting more brakes.
Old 07-03-2014, 11:15 AM
challenger2k
Holden 10 ton trailer (Ameritech)
Thanks for the feedback guys. The backhoe should be fine.
Darn, I just finished restoring the trailer before I got the excavator, it's a Komatsu PC100-6, 23,500 lbs.
I can't find the GVCWR for a '92 F700 anywhere. I want to be around 50K lbs. Things get costly above 54k.
I hope I don't have to invest in another truck and trailer. This 5-6 yard truck is perfect for residential work, and the trailer was just restored, oh well.
Thanks again for your help,
Old 07-04-2014, 11:04 AM
dmanlyr's Avatar
dmanlyr
dmanlyr is offline
The GCWR is easy to find, at least the maximum properly equipped, it is listed in the sales brochure. You are most likely looking at a MAXIMUM of 42k as a GCWR, that is the standard on F700 thru at least the 60's to 70's.
It is also listed in some of the owners manuals.
David
DocB
Fifth Wheel & Gooseneck RV Towing
18
02-16-2012 01:27 PM
Patchez
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
15
09-13-2011 01:35 AM
D.S.
09-27-2004 08:16 PM
FishOnTheBrain
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
09-06-2004 02:50 PM
Inspector_77502
1997 - 2003 F150
11-25-2002 12:40 PM
Quick Reply: F700 GVCW ??
