Auto trans behind flathead
Old 06-30-2014, 07:27 AM
tip49's Avatar
tip49
tip49 is offline
I have a line on an 8BA flattie, and am currently running an AOD transmission. Have done some research but has anyone actually spent the money to bolt one up ? It may turn out that the flathead may not be salvageable but I would like to plan for best case scenario.
Tom
Old 06-30-2014, 09:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
C-4's are pretty common behind flatties so it should be possible to put an AOD off a 302 behind one. Hooking up the throttle cable would be the tricky part, I'd guess. Try a google search, somebody on the HAMB or Ford Barn is sure to have tried it.
Old 06-30-2014, 03:22 PM
tip49's Avatar
tip49
tip49 is offline
Thanks Ross
I would be a long way off, but may pick up the flattie this summer/fall
Old 06-30-2014, 03:28 PM
NC-51-F1's Avatar
NC-51-F1
NC-51-F1 is offline
Speedway has a kit...
910-28907 from Speedway Motors, America's Oldest Speed Shop
I'm sure the individual parts are available if you already have the trans.
Hope this helps...
ctaylor57 f100
08-15-2012 06:10 PM
ctaylor57 f100
08-13-2012 08:59 PM
Hitokori
12-04-2009 05:53 PM
bfbiker
12-08-2008 11:39 AM
neon4x
08-26-2007 11:15 AM
Quick Reply: Auto trans behind flathead
