6.2L V8 Discuss the 6.2L V8
Towing Capacity F250 6.2L Crew Cab 3.73 Axle
Old 06-27-2014, 10:09 PM
haffner226's Avatar
haffner226
haffner226 is offline
What is the recommended towing capacity of a 2013 F250 6.2L Crew Cab with a 3.73 axle. I read that the capacity is 12400, but that seems low. Any help would be appreciated. Looking at buying a 5th Wheel with gross of 15,500.
Thanks,
Old 06-28-2014, 02:31 AM
Butl85's Avatar
Butl85
Butl85 is offline
Thanks,
That is your capacity. For 15.5 you are going to need a diesel. I would have to look it up but I think the only 6.2 that might put you near 15,500 is a 350 single cab with 4.30 gears.
Old 06-28-2014, 04:51 AM
T diesel's Avatar
T diesel
T diesel is offline
The heaviest you can tow with a 6.2 is 15,700lbs.
F-350 drw 4x2.
http://www.ford.com/resources/ford/g..._SuperDuty.pdf
Old 06-28-2014, 07:40 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
My 2013 SC 2wd DRW 4.30 gears is rated to pull 15600, our trailer is 15900 last year when I weighed. Your biggest problem is the 3.73 gears and the weight you will be putting on the truck, our trailer puts 3200 to 3400 lbs on the pin. You also have to look past all the ratings and look at the trailer, will it have standard undersized brakes that most units come with or have they been upgraded, when we ordered ours we upgraded to Dexter HD brakes 12 x 2 to 12.25 x 3.375 big difference. Remember it's not only pulling it it's also stopping.
Denny
Old 07-15-2014, 01:05 PM
-brent's Avatar
-brent
-brent is offline
Good point!
Old 07-23-2014, 07:42 AM
Retread65's Avatar
Retread65
Retread65 is offline
** What Denny said !! **
It can't be said enough times. I saw a 12,000 lb travel trailer being pulled with a Chevy Luv once and I got as far away from them as fast as I could. I'm sure they were proud of themselves.
Old 07-23-2014, 08:33 PM
BigMix's Avatar
BigMix
BigMix is offline
As for brakes, my understanding was that all 13's and newer had larger rotors than the 11's and 12's. I didn't even realize that there was a better option.
Old 07-23-2014, 08:40 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
The better brakes being referred to above is on the trailer not truck
rvpuller's Avatar
rvpuller
rvpuller is offline
If your talking about my post I was talking about upgraded brakes I ordered as a option on our trailer.
Denny
Old 07-23-2014, 08:59 PM
BigMix's Avatar
BigMix
BigMix is offline
Denny
As I read that again, it was clear you were referring to the trailer. Too long of a day at work I guess.
dbossman
2017+ Super Duty
02-17-2017 11:01 AM
MMMMGas
02-12-2017 03:17 PM
Craig250
1999 to 2016 Super Duty
16
07-13-2009 08:52 PM
lsever
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-12-2008 03:00 PM
Floater
03-25-2004 09:29 AM
Quick Reply: Towing Capacity F250 6.2L Crew Cab 3.73 Axle
