2007 F150 Lariat Super Crew Power Window and Folding Mirror Problems
#1- The power windows only operate from the driver’s side Master Control Switch. I replaced the Driver Master Control Switch and the condition did not change. I checked all related fuses and rotated Relays and was unable to isolate the problem to the Fuse/Relay Panel. What else could be blocking power from getting to the other window switches when the Driver Side Window Lock Switch is in the off position?
#2- The Power Folding Mirror function no longer works, however; the adjustment functions do work. Is the problem isolated to the Driver Side Mirror Control Switch or could there be a relay or fuse issue?
Operating Power is getting to each individual motor from the Driver's Side Window Control Switch. When the Driver's Side Window Lock Switch is turned off, which normally enables the individual Window Switches to also control the windows, there is no power being transferred to the individual Window Control Switches.
Texasdeereandhorse
1999 to 2016 Super Duty
05-02-2019 09:12 AM
fod
06-07-2011 01:12 PM
00GT
04-27-2007 11:34 AM
