My front differential is leaking. Are there any special Ford tools required to replace the seal? Or is it simply bolt (and fluid) removal, seal replacement, fill with new fluid. Any tips or heads-up on this?
Thank you
are u talking axle seal?
i just did one on a 05. straight forward remove cover remove clip on axle,
remove cv shaft. if it is on pass side remove axle housing after you slide axle out part way.
took about 2 hours to do
good luck
tom
To be honest, I'm not sure where the leak is coming from; I thought it was just from the diff cover. To be sure I guess I should clean it up and then see where the leak is coming from...
