I have a 2006 King Ranch and right tail and brake lights dont work. the bulb is good. the fuse diagram in the owners manual is not the fuse box I have, so I cannot id the correct fuse to see if its bad. any ideas?
Hi tedsfi,
I checked out the 2006 Owner's Manual and it looks like they're up to their fourth revision. I found fuse info starting on page 236; I'd recommend checking it out to see if that helps. You can download a free copy of the fourth printing here: https://owner.ford.com/servlet/Conte...OwnerGuidePage
If both the stop and the running lamp are both out, it's not going to be a fuse problem anyway. It's going to be either a defective bulb, socket, or an open ground for the bulb. Pull the tail lamp assembly out and check the black wire. Might have had a critter get in there and chew stuff.
