Question for changing brake pads
Recently I read a thread about the right way of changing brake pads. It stated NOT to push the brake fluid back into the line, it might damage the ABS system. Instead, open the breeder when pushing the piston back.
I remebered that last time I changed the pads in the truck, I just pushed the piston / fluid back to the line. I encountered no problems what so ever... may be I was just lucky.
Can some one tell me what is the proper way to re-set the piston back?
Thanks.
Thanks.
Note ,...They seem flat , but get a sheet of drywall sandpaper , lay on a good flat surface , and rub the new pads on it about 6 times to true up the surface , works great .
I used Mastercraft OEM brake pads last time but not too happy about the braking performance. My truck is a daily driver with 3/400 lbs in the bed and regularly needs to tow a trailer with 2/3000 lbs in it. I would like to have stronger braking power at all times. I am thinking of brand name ceramic brake pads such as Raybestoes, Bendix or Hawk. Any suggestions or they are pretty much the same? Do they "eat" rotors ... my truck is a 2wd so the front rotors and hub are one unit, very expensive and hard to replace. Any suggestions are welcome.
Thanks,
Peter
Thanks,
Peter
Thanks,
Peter
Thanks,
Peter
Thanks,
Peter
Thanks,
Peter
I use ceramics in my daily driver because I don't like brake dust and I don't haul heavy loads or tow a trailer. If I did I would go with semi-metallics.
If you need to replace your front rotors, I went with the Centric two piece conversion, so in the future I can just replace rotors like a 4wd
