1948 F6 Fire Truck Frame Off Resto
Hey guys I joined up here to get a little input on a 48 F6 Fire Truck we are building. It will be a full frame off restoration. However, it will be rebuild with a modern drivetrain and some other conveniences. The owner wants reliable transportation and will be using it to advertise his business. We will remove the rear ballast tank and install seating and some other conveniences. We are probably looking at installing a 351 crate motor and automatic transmission.
I was looking for some advise on front and rear suspension. We would like to have disc brakes on the front and would also like to replace the 2 speed rear end with another rear end. We didnt know if an older E350 Ford van striaght axle would work in the front and a possible dually rear end from a ford P/U. I have done a little research but know all of the knowledge is here on this forum. We typically do complete frame off restorations on muscle cars and build customs. We are really looking forward to stepping out of the box a little and having some fun with this killer Ford. You can check us out at GodSpeed Rides.
thanks, Mark
thanks, Mark
Yeah, they are widow markers. Please let all the air out of the tires before doing a lot with them then do a Google search for "Firestone RH-5°" rims.
To your question, I'd suggest finding a junk '70s era Dodge RM400/500 motor home that could donate its 19.5" tubeless wheels and Dana 70 rear axle. These have the same 5 lug x 8" bolt pattern that lets you keep the truck looking period correct, and gives a 4.56/1 rear ratio for improved road speed. The rear axle is nearly a bolt in swap. To my understanding the spring perches are about 1/8" off meeting up perfectly to the springs which mean you'll only have to grind the corners of the perches on one side to allow the hanger bolts to clear.
The front axle will be more challenging. Some of these motor homes did have disc brakes. I had a similar project planned and had gathered the pieces, but changed plans and sold the rear axle and Alcoas. I still have the front hubs and discs to see myself someday whether the pieces can be adapted to the stock F-4/5/6 front spindles. I doubt you'd be able to use the whole donor front axle without doing some serious re-engineering of the steering. Your fire engine has the steering drag link and pitman arm outside the frame rail while more modern vehicles have all these pieces inside the frame rails to comply with government rules blah, blah, blah. But the old spindles might take the newer components with some machine shop help. So, that's what I can suggest. Welcome to the group. Stu
Welcome, and check out these threads:
https://www.ford-trucks.com/forums/1...ire-truck.html
https://www.ford-trucks.com/forums/1...heetmetal.html
In my opinion, that truck just isn't going to look right with smaller wheels and tires on it.
Most all modern trucks have much wider track width, so finding donor axles that use bigger wheels will be a challenge.
My suggestion would be to keep the OE axles, upgrade the wheels and brakes and add an OD trans.
To your question, I'd suggest finding a junk '70s era Dodge RM400/500 motor home that could donate its 19.5" tubeless wheels and Dana 70 rear axle..........
The front axle will be more challenging. Some of these motor homes did have disc brakes. I had a similar project planned and had gathered the pieces, but changed plans and sold the rear axle and Alcoas............... . So, that's what I can suggest. Welcome to the group. Stu
thanks for the clarification
Daaaayum! You folks don't waste much time, do you?
I think your sheet metal looks to be in pretty (very) good shape. I'm giving some thought to a Gear Vendors' divorced overdrive myself.
Nice thing about the 22.5s is that they are radials. Them thar "yuppies" might kin do better on radials.
thank you.
It has been a tremdous amount of work. They come apart alot easier than they go back together.
This truck is in really great condition. We have had some sheet metal repair. We just set up our sheet metal shop here and not too soon. Thom takes care of all the metal and he does a fabulous job!
Nice project! Is that a Hale or Waterous pump? It looks like a 500 or 750 gpm pump. If you aren't going to reinstall the pump, you might put out some feelers with local VFDs about the pump. Some of them might need the pump or be able to use it for parts on a rig that is still in service.
