tranny problem
Old 05-18-2014, 07:48 AM
bra$$monkey's Avatar
bra$$monkey
bra$$monkey is offline
tranny problem
I picked up my 2005 F150 4x4 last winter.
it has 135k miles & a slight tranny problem.
When cruising around 45 mph - right between where it wants to be in top gear or not - if I slightly accelerate the trans BANGS between the two gears.
I mean repeatedly bangs - it is not a smooth shift where it can't decide which gear to use - it is a hard BANG where it can't decide which gear to be in.
What gives? I can usually stop it if I turn on the towning button - shutting off high gear.
Old 05-18-2014, 11:01 PM
steelhead2's Avatar
steelhead2
steelhead2 is offline
Whats the fluid look like?. Been serviced recently? I would start there. Im no trans expert but it sounds like maybe your torque converter is giving up on you.
Old 05-19-2014, 03:16 PM
twfish's Avatar
twfish
twfish is offline
Are you at a lower rpm when it happens? Sounds like a coil pack
Old 05-21-2014, 01:54 PM
bra$$monkey
its not a coil pack - its certainly in the trans. It happens when cruising in OD & I slightly accelerate. Really whacks between OD & 3rd.
Old 05-21-2014, 04:46 PM
twfish's Avatar
twfish
twfish is offline
Does it jerk or is there an actual sound? Does it do it at a higher speed or just at low rpm?
Old 05-22-2014, 10:59 AM
bra$$monkey
It makes a bang & I can feel the truck shutter & buck - it stops if I turn off the od with the towing button.
Old 05-22-2014, 09:14 PM
fordforlife1986's Avatar
fordforlife1986
fordforlife1986 is offline
hey there I am having a similar problem with my 2007 f150 and I was wondering if you ever found out what the problem was? if it was something with the tranny or coilpacks ect.
Old 05-30-2014, 03:31 PM
mchemical's Avatar
mchemical
mchemical is offline
Unhappy Transmission bucking around 45/50 mph
I have been having the same problem with my 2004 5.4 engine transmission for several years now. If I am traveling in that mph range I just turn off the OD.
Old 05-30-2014, 08:18 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
I bet you have a bad plug or coil. There can't be anything wrong with the trans to make it shift like that. To go from 3rd to 4th the forward clutch releases and the OD band applies. It can't happen fast enough back and forth to give a bucking sensation. You prob have a plug that has carbon tracks on the outside and when conditions are right the spark jumps to ground outside the plug instead of through the plug. Pull each coil and closely inspect inside each boot for the tracking.
Old 05-31-2014, 03:18 AM
ford-lover's Avatar
ford-lover
ford-lover is offline
I had the similar problem and was thinking it was tranny problem ( convertor stutter). Did the trans fluid flush. The problem continued and got worse by the week. Finally replaced all spark plugs with SP515. The problem disappeared since and is running silky smooth now. By the way, the plug change job was done by a local dealer and I was told all spark plugs came out in one piece. Lucky me!
Old 05-31-2014, 07:14 AM
70f100longbed
Converter shudder really doesn't feel like a buck, it feels more like driving over rumble strips for a second as the torque converter clutch applies. In OPs case the truck had 135k miles when he got it so there is no telling what kind of maintenance was done or not done. Also someone could have washed the engine to make it look pretty and got water past the coil boots.
Old 06-01-2014, 11:11 AM
skunkoffroad's Avatar
skunkoffroad
skunkoffroad is offline
I love when people need help with something but are too much of an expert to listen to anyone.
Good luck
Old 06-01-2014, 02:28 PM
bigunit54's Avatar
bigunit54
bigunit54 is offline
I was going to say it was very good advice by 70f100longbed. His advice is always spot on.
Old 06-04-2014, 04:51 PM
gijim2k1's Avatar
gijim2k1
gijim2k1 is offline
I have found the search button to be very useful on this forum.
Ford Truck Enthusiasts Forums - Search Results
changing plugs solved my problem, some have required coils too.
Old 06-04-2014, 05:14 PM
bra$$monkey
Thanks for the advice guys. I'll Change the plugs this weekend.
Sounds like everyone knows what's up.
Except for skunk - who was that comment directed at?
dcc1993
03-24-2019 10:53 AM
lincolnboy73
13
08-17-2012 04:41 PM
1991Brutus
1999 to 2016 Super Duty
01-24-2012 11:22 AM
totavikid
03-01-2006 12:30 PM
Cfdchf
12-30-2000 09:01 PM
Quick Reply: tranny problem
