Oil pressure and cam shaft sensor question
Old 05-01-2014, 09:28 AM
tgowers's Avatar
tgowers
tgowers is offline
I have a 2007 f150 2WD 5.4 with 139,000 miles on it, and I bought it new. I just spent crazy money having all of the part below changed:
Dorman cam phasers
Cam shaft sensors(twice)
Water pump
Thermostat
Oil pump
Crank shaft sensor
COMPLETE timing chain set-up
Alternator
Belt and pulleys
Spark plugs
All associated gaskets
Now the truck starts sold and has a rattle for a split second, then runs smoother and quieter than when it had 1 mile on the engine. You drive it, and it runs smooth until it is at operating temp, then at idle it rattles and shakes like it's coming unglued. Tap the throttle and it smooths out until it settles back to idle. I cleared all the codes and then drove 30 minutes to work. Right after work I went to the auto parts store to have them read the codes: 7 codes P0012, P0022. P0012, P0022, P0345, P0340, P0345
All of these are bank 1 and bank 2 cam shaft sensor / over-retarded timing.
My question is since the Cam Shaft Sensors were both replaced twice in the same day. The mechanic told me that there is an oil passage blocked in the engine block. He said that the oil pressure at cold start is 65psi until it warms up, then it drops to 25psi, which he said is stock. He said that when it's warm there is not enough oil getting to the CPS which is not allowing the cam phasers to activate, thus not advancing the timing. The oil pressure gauge in the cluster shows the needle just above the middle line at all times when at idle and highway speeds. The truck has NO POWER in passing gear, and no power from a dead stop with the pedal to the floor. I think that the mechanic didn't get the engine timed correctly. I need some input on this one guys. How can the timing be adjusted on these engines? Thanks!
Old 05-02-2014, 08:50 PM
VTX1800N1's Avatar
VTX1800N1
VTX1800N1 is offline
The oil pressure gauge in the cluster is little more than an idiot light. It doesn't change with actual oil pressure.
It's likely the Doorman phases have failed. They are junk. Motorcraft is the only way to go for phasers.
Old 05-02-2014, 08:59 PM
Ford'05HG's Avatar
Ford'05HG
Ford'05HG is offline
I put the TechSmart phasers in 2 months ago and they are still doing great 7k miles later.
I think my choice of not replacing a rocker is causing my oil pressure to be slightly below spec and so the phasers tick every now and then and sometimes not at all when idling.
Think that has something to do with temp getting excessive. Haven't checked the cooling system yet.
Old 05-02-2014, 11:30 PM
Ford'05HG's Avatar
Ford'05HG
Does anybody think sea foam oil treatment would be smart for these engines?
Old 05-06-2014, 07:24 PM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
If the power is flat at both low and high rpm applications I would say your timing suspicion has merit. Especially when you look at the codes its producing. To fix it you have to take it back apart and re-index the gear sets. I think the mechanic might have a blocked oil passage in his head.
Deckmonkey
2004 - 2008 F150
12-10-2023 02:08 AM
eigenvector
1983 - 2012 Ranger & B-Series
10-31-2016 08:00 PM
alwaysFlOoReD
2004 - 2008 F150
16
12-10-2014 12:35 PM
BStreett
2004 - 2008 F150
10-21-2011 07:05 PM
bodine44
01-21-2008 11:50 AM
Quick Reply: Oil pressure and cam shaft sensor question
