Fan for my 52 F5
Old 04-15-2014, 05:02 PM
Joshua Farm's Avatar
Joshua Farm
Joshua Farm is offline
Fan for my 52 F5
Can anyone help me ID a fan for my 52 F5 8RT engine? I have an alternator with fan mount on water pump. I can't find which one or even something close. I'm not even sure what came stock on it. I'm pretty sure it was a four bladed fan. However, I have had no luck finding one. It looks like I might just have to do trial and error retro fitting. I can't live with the electric one that is on it now. It vibrates more than the engine.
Old 04-15-2014, 06:03 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
I don't quite understand what setup you currently have. The flathead V8 (8RT) did not have a generator or water pump mounted fan. The six cylinder had a water pump mounted fan.
The fan setup for your F-5 should look like this (with either a 4 blade or 6 blade fan):
Old 04-15-2014, 06:13 PM
Joshua Farm
My mistake oops, but lots of confusion
You are absolutely correct, sir. However, I can't find any aftermarket sources for the four bladed fan.
Old 04-15-2014, 06:29 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
I would think if the electric fan vibrates it has lost a blade or balancing weight. Usually, electric fans are quiet and pretty much vibration free.
Old 04-15-2014, 06:40 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
The parts book actually calls for a 5 blade (18.5" dia) part# B7Q8600C. The parts book shows ONLY 5 blade fans for all trucks 1948-56, so I wonder if the 4 blade was supposed to be on the passenger cars.
38 Coupe, I see you changed the pic you posted, where was that one from, as it indicated the fan part # to be 8602?
Anyhow, Part #B7Q8600c
Dennis Carpenter has 2 NOS
Klimesh Motor Sales Calmar, IA 52132 has 2
Miller Obsolete Binghamton, NY has 1 $90.00
Old 04-15-2014, 07:08 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
I think maybe the V8s are all 5 blade. My I6 is a 4 blade.
Old 04-15-2014, 07:12 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
I was searching through photobucket for good picture that someone else had already made available. The earlier picture is actually a 1949 car engine, but the fans are similar. I updated it when I found a picture of a truck engine.
Here is the earlier picture:
The only 5 blade fan I have seen on a flathead was on a 53 truck motor and was definitely a one year only assembly.
Old 04-15-2014, 07:19 PM
harleymsn's Avatar
harleymsn
Here's what the parts book list.... I found Van Pelts list 8602 as a fan/hub combination
Old 04-15-2014, 07:21 PM
Joshua Farm
This is what I'm saying
You can do a parts number search for it all day long and not get anything close. My local parts stores are worthless. Anybody have a Part #B7Q8600c
18.5" diameter 5 blade fan for a 1952 8RT flathead V8? Used condition would be fine. I have to ditch the electric fan!
Old 04-15-2014, 08:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
So are you missing the whole assembly, including the hub and mounting bracket?
Old 04-15-2014, 11:22 PM
Joshua Farm
Just the fan
All I need is the fan. Anybody know where I can get one?
Old 04-15-2014, 11:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What was wrong with these (below)?
Old 04-16-2014, 05:51 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Or if you like that auction site:
http://www.ebay.com/itm/1946-1947-1948-FORD-FLATHEAD-Aluminum-Accessory-Cooling-FAN-BLADE-for-Restore-/281309515686?pt=Vintage_Car_Truck_Parts_Accessories&hash=item417f5a8fa6&vxp=mtrhttp://www.ebay.com/itm/1940S-50S-FORD-RAT-ROD-FLATHEAD-Fan-Pulley-Mount-for-Restore-A-8632-/281309515682?pt=Vintage_Car_Truck_Parts_Accessories&hash=item417f5a8fa2&vxp=mtr
Old 04-23-2014, 08:17 PM
Joshua Farm
Fan search
I called all listed sites and no one had one on the shelf. I bought the 5 blade aluminum one and pray that it will work.
Old 04-23-2014, 08:20 PM
raytasch's Avatar
raytasch
Believe Nothing
Quick Reply: Fan for my 52 F5
