93 3.0, wont pass emmisions.
I have a 93 Ranger with a 3.0 with 225k on it and I am trying to pass emmisions in Tennessee. I had it tested once and my HC was to high so home I go change plugs and wires, run 2 tanks of 93 octane thru it and take it back today and now my HC level is higher than b4. Any good suggestions out there about what to try, I was thinking of running a can of Guarenteed to pass thru it and see what that does. One friend said Seafoam but Im not sure if that will work.
High HC is a rich mixture or burning oil.
Is your PCV system working ok? Is your engine making a lot of blow-by? Did you do an oil change right before the test?
Your vehicle is OBD I, right? Pull any codes?
Ford Check Engine light Codes - FreeAutoMechanic
Yes it is an obd1 system and pulling no codes. I haven't done an oil change recently and replaced the pcv around 3 months ago. I don't know how to test for blow by but I don't seem to lose any more oil than normal and notice no smoke. I usually use Lucas in my oil but I didn't last oil change cause it was so cold here in Tennessee. I prolly need to add a quart of oil so I might put a quart of Lucas in it.
Try fresh oil. You will eliminate gas fumes from any dilution caused by wear and blow by. Check this, covers the subject:
AirCare emissions testing program | Repair Info - Causes of Excess HC Emissions
What did you blow on CO? Usually, high HC will cause a CO fail as well.
78Hayride
09-20-2018 01:19 PM
60RatRod
08-01-2010 03:56 PM
