Back in the Bio again!
Old 04-05-2014, 04:40 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Just thought I'd share, it's been a long cold winter. Washing one batch of fuel and just started another. I miss my $1.20 / gal fuel...
Old 05-28-2014, 05:05 PM
jamusfam's Avatar
jamusfam
jamusfam is offline
I'm looking at doing the same I've invested into a 86 6.9 diesel. Let us know what you found was the best techniques and things that work best. I got 5 55 gallon plastic drums that I'm going to use collect and make.
Old 05-28-2014, 10:50 PM
Rushmore X's Avatar
Rushmore X
Here are the steps I use:
1. Collect WVO
2. Filter WVO to remove large chunks
3. Fill reactor w/ 37.5 gallons of oil (using 50 gallon water heater)
4. Heat to 125 and add glycerol from last batch
5. Circulate and let glycerol settle out.
6. next day - drain glycerol, recover methanol from it.
7. Test Titration Levels of WVO
8. Heat WVO to 125 F and turn off heat
9. Add Methoxide (5 gallon methanol + about a gallon recovered from prior batch) to Heated WVO slowly, about 20-30 minutes
10. Mix the mixture for about 2 hours(pump mix)
11. Let it sit
12. next day - Drain off Glycerin from the bottom of tank, save for treatment of next batch
13. Recover Methanol then dry wash with Magnesol. Let set a couple days.
14. Filter bio
15. use bio
I pretreat due to some of my oil is rather acidic. by pretreating I neutralize some of the acidity. If you have really good oil you can skip this step, might want to anyway... I just seem to get better bio this way...
Old 05-29-2014, 10:39 AM
flainn's Avatar
flainn
flainn is offline
I really miss making bio. Someday ...
Old 05-29-2014, 04:39 PM
Rushmore X's Avatar
Rushmore X
I really need to find another source of oil, have enough for one more batch...
Old 08-07-2014, 02:38 PM
Tom D's Avatar
Tom D
Tom D is offline
Welcome back Jim. I knew you wouldn't quit. I'm still plugging along. I don't recover my methanol. Pain in the butt. What is your recovery process? Maybe I am not doing it efficiently.
What happened with the methanol/KOH mixture? Did it get too hot? I notice the mix gets very violent when it is hot out. I leave plenty of ullage space when pouring in KOH and I do it in 2 steps (4gal methanol/2 lbs KOH)
I've been very busy so I don't get on this Forum much any more. I see there is a new "breed" on here now. Lots of WMO processors. I'll stick with WVO. Don't think I'll ever go with WMO. Fabman would "be all over me like a cheap suit" There are still some of us "purists" around.
Good luck with your endeavors.
Tom
Old 08-07-2014, 07:16 PM
Rushmore X's Avatar
Rushmore X
I just recover the methanol from the bio. It does take a little time to heat up the processor to 185 and distill it off.
Yes, I did mix the 2 when it was near 100 out, you're right - very violent reaction. won't do that again...
A/Ox4
Bio-diesel, Propane & Alternative Diesel Engine Fuels
18
04-13-2012 10:33 AM
whiteaddiction
10-28-2009 09:54 PM
Rushmore X
02-16-2009 12:51 PM
6.0superduty
03-19-2008 11:44 AM
RDC F250 7.3
18
07-31-2006 09:38 PM
Quick Reply: Back in the Bio again!
