1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear marker lights
Old 04-02-2014, 06:29 AM
Bazillions's Avatar
Bazillions
Bazillions is offline
Rear marker lights
Want to add the rear marker lights on my 2012 SD like the 350's have. Is there already a lead there to plug in to already or do you have to tap into the harness. If you have to tap into it does anyone know which wire and where is best?
Old 04-02-2014, 08:24 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
I tapped into the tag light. super easy. I used a bit of silicone on the scotch loc connectors to keep out moisture. The light I used was a Grote 49182 from amazon.
Old 04-02-2014, 09:05 AM
Bazillions's Avatar
Bazillions
Same light I'm looking at. Claims to be replacement part. I haven't looked at space under bed. Did you have to drill?
Old 04-02-2014, 09:22 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
no drilling on the truck. I used number 10 stainless steel bolts. it fits great I installed mine last night. I did make the holes a tiny bit bigger on the light but no need to drill your truck.
Most of the light bars I have seen were like 7 1/2" centers on the holes and our holes are like 16" centers I think. get the grote light you will be happy
Old 04-02-2014, 10:30 AM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
I installed mine a couple years back, I used the trucklite brand (#15745 I believe... ~$20 at Napa) and it fit perfect on my 07. I cut the wire to the driver side plate light and then joined the new wire in with a reducing butt connector, then heat shrink and wire loom, looks just like a factory install under there. I love how they dress up the rear end!
Old 04-02-2014, 10:35 AM
Bazillions's Avatar
Bazillions
That's the info I needed, thanks!
Now to move on to puddle lights....
Old 04-02-2014, 11:20 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
Like this...
I got the led strip from amazon and used half on one side and half on the other. Comes on when the doors are unlocked or doors are open. I tied into the plug on the frame that the lariats have.
AspenTek 12v 16.4 Ft 600 Leds 3528 Flexible LED Strip Coated in Clear Waterproof Sleeve Ip67, Cool White(6000k)ideal for Bedroom, Bathroom,dinning Room, Stairs,corridor,kitchen,garden,hotels, Restaurant, Ktv, Bar and Other Outdoor Using
Old 04-02-2014, 11:22 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
The leds come with 3m sticky tape but I added silicone on both sides to hopefully help it stick better... Time will tell.
Old 04-02-2014, 11:24 AM
Trophy_23's Avatar
Trophy_23
I love that!! Those on the dome light circuit? I remember seeing the other thread but can't remember where you tied in.
Old 04-02-2014, 11:25 AM
Bazillions's Avatar
Bazillions
Yep, that's what I'm looking at. I have the plug on the frame. I'm not sure how to mount the strips or exactly where. I'm concerned about the ice and snow pulling adhesive off where I'm at.
Old 04-02-2014, 11:30 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
On some of the trucks there is a plug on the frame that you can use a metra speaker adapter to tie into. But yes it is the dome circuit.
Old 04-02-2014, 11:32 AM
Bazillions's Avatar
Bazillions
That pic is making me want more lights now. Sharp truck.
hpwoee's Avatar
hpwoee
hpwoee is offline
That's why I added the extra silicone. I also have the factory mud flaps so I'm hoping that will help. Like I said I don't know how long it will last yet I haven't had it on there very long
Old 04-02-2014, 11:33 AM
Bazillions's Avatar
Bazillions
Where did you mount them, the vertical flange underneath?
Old 04-02-2014, 11:35 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
Lol it is a sickness! The top lights are the atomic led strobes and the lights in the bottom air dam are 3/4" leds. Took all I had to drill all those holes in a brand new truck!
Quick Reply: Rear marker lights
