Gasoline in a diesel engine = best mileage ever?
Old 05-07-2014, 12:43 PM
parkland's Avatar
parkland
parkland is offline
Originally Posted by madpogue
^^^^ Um, the math is easier if you DON'T convert to gallons. 20-liter pail of oil for $30 is $1.50 / liter, 5 cents a liter more than the diesel. So it's close.
Stateside, we're paying aprx. $4/gallon for diesel. The "pails" of oil here are 5-gallon, and even the cheapest oil is aprx. $40/pail, so about twice the price of fuel. So Canada is experiencing cheaper oil, and more expensive fuel, than we get.
So why does that article, after talking about getting rid of the throttle and spark plugs, show an animated diagram of an Otto-cycle engine?
I think the concept in the article was using a diesel pilot injection to ignite the gasoline instead of a spark plug, thus igniting it far better than from a single spark.
And as far as the oil being cheaper, yes the engine oil is slightly more, but has higher BTU content than diesel, so more BTU's per dollar $ .
Old 05-07-2014, 02:13 PM
flainn's Avatar
flainn
flainn is offline
Ohh, okay, I getcha.
Well, heck, I'd love to try it in my 6.0 (matter of fact, I found a cubie of virgin salad oil that had expired for half price at Wally World the other day) but I'd probably better get the other issues ironed out before I start on the alternative fuels again. It's not nearly as forgiving as my IDIs were.
Old 05-07-2014, 05:30 PM
parkland's Avatar
parkland
parkland is offline
No, not at all.
Something I didn't know, was that some veg oils can really degrade into "skins" and "chunks" when being heated, so not only is filtering a major thing, but also what type of oil, and if it will be stable when heated, and stored, sitting in fuel lines, etc.
Just cause it's been filtered and dewatered, doesn't mean it's going to work.
Different oils also burn different, I have a little air cooled diesel, and when you fuel it on furnace oil or straight veggie oil, it knocks a lot louder than on diesel from the gas station.
I'm guessing from lower cetane values than road diesel. So you'd also want a cetane booster to keep from putting extra stress on the head gaskets. IMHO.
The anatomy of 7.3 and 6.0 injectors should really work the best with waste oils, in theory, than other injection systems. In practice, they are expensive injectors and the quality of the prep done on most waste oils is less than what I'd consider running in them.
Old 05-27-2014, 09:33 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
Wouldn't it be better to just retard the timing a little?
If you use a luminosity probe, you ought to be able to adjust your timing to be perfect for whatever you end up throwing in the engine.
Old 05-27-2014, 10:22 PM
parkland's Avatar
parkland
parkland is offline
Yeah but if you plan on burning a bunch of different fuels, is it easier to add cetane booster to some, or adjust the timing for some?
Old 06-05-2014, 08:41 PM
wtroger's Avatar
wtroger
wtroger is offline
My cousin runs 2 gal gas with 8 gals triple filtered wmo. runs good
Old 06-12-2014, 07:48 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
How do you retard a diesel? There is no spark plug... ??
Sent from my Sprint PC36100 using IB AutoGroup
Old 06-12-2014, 08:31 PM
madpogue's Avatar
madpogue
madpogue is offline
Um, the injection is timed.....
Old 06-12-2014, 09:14 PM
F239141's Avatar
F239141
F239141 is offline
Remember the old duce and a half trucks that ran on diesel, gas, jet fuel etc etc
Old 06-12-2014, 10:16 PM
flainn's Avatar
flainn
flainn is offline
Remember them? Hell, between two of my friends, there are three of them close at hand.
Old 06-12-2014, 10:17 PM
flainn's Avatar
flainn
flainn is offline
Maybe he was talking about Cummins owners?
Old 06-20-2014, 02:29 AM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
my source dried up, 0-20 full syn, and ATF but have some saved for rainy day, 50/50 still runs great, diesel is around 47 cetane some mineral oils are 70, mineral oil is used as industrial coolant (transformers), to much gasoline and you will have problems, not limited to IP wearing out. wife drags horse's no starting problems, no smoke, timeing 7.5* BTDC factory fuel system. NA
lud04X
General Diesel Discussion
07-08-2014 12:35 AM
60RatRod
11-11-2008 01:42 PM
DMOtwell
6.4L Power Stroke Diesel
07-19-2008 09:50 AM
sneak
Oil & Lubrication
05-18-2006 08:59 AM
02GrayPowerStroke
02-01-2006 05:35 PM
Quick Reply: Gasoline in a diesel engine = best mileage ever?
