The new SMALLER 2015 F-150!!
It depends on which cab you're looking at. The crew-cab short bed truck is actually slightly larger than current truck in wheelbase, width, and track. Whereas, the regular cab/standard bed truck is significantly shorter in length and wheelbase.
The new truck does average about a 1 inch shorter reach-over height into the bed. Might not seem like much, but it really has impact on the visual proportions of the truck.
Straight from the may/june 2014 Truck trend:
the truck is wider but it's about the same length and height as it was in 2014. The body mounts were moved outboard. The rear leafs were shortened and the front track is 15 millimeters wider.
The front doors and windows have been pushed forward, the base of the windshield has been moved forward, the edge of the front windows have been pushed forward 4 inches, the bottom front edge of the glass has been lowered 2 inches and the rear cab glass is now flush mounted.
The Screw trucks will get slightly over 700 lbs in weight reduction while the smaller cabs will see a little less. Payloads and towing capacities will be increased by the weight reduction.
Starting in 2015, Ford will strictly adhere to the recently revised SAE J2807 tow ratings and GM/Ram are expected to follow suit.
Remember when the 2009's first started hitting the dealers? We all commented on how they looked shorter and smaller than the 2008's. Simply not the case.
Who cares if its aluminum? Its alloyed with Magnesium (5000 and 6000 series aluminum) so it'll be light weight and rigid. Plus you do know that when you bend metal a certain way it becomes stronger. We've had this discussion before. It wont have the galvanizing effect people were worried about.
IMO, 2004/2014 F150's have the best looking dashes of any Ford trucks, and I've bought 8 of them new. 1965 F100 was the first, 2011 F150 most current.
